winch wiring
rooster
6
0
Hello everyone I am from Idaho and new to the forum. Where have ya, been mounting your winch contactor block?
Mine is under the hood. Jevu6y2y
63,963
Welcome Rooster to the community.
I mounted mine is same spot but on the opposite side.
Make sure you pre-wire it up to insure you have enough wire before you secure it in it's final place. I had to move mine 2 inches to allow the wired to fit after I mounted it.
It did require using the long wires for the (battery to contactor). Where normally these are the (contractor to winch) wires.
I have the KFI SE45 and had to do the same. The contactor would fit in the battery area, and I didn't want to stick it under the drivers seat where it'd get covered in everything I ran over.
rooster
6
0
Thanks guys. Prewiring good tip. Ohanacreek, I viewed some of the stuff you are doing with the switches and the template it looks great. you must be an EE. Thanks again.
Jack of all trades, master of none.
