Windrock1000 submitted a new Garage Item:
Windrock 1000's- She's Foxy Now
Mines not glass... I'd have one otherwise!
Nope I. Sure it's strictly prohibited.Does anyone know if they allow you to bring pressure washers to the camp?
$50 in quarters will due then! LMAONope I. Sure it's strictly prohibited.
@Windrock1000 damn you I thought I was done. Ok thanks so much for the info I owe ya one! Thanks for looking out.Found a problem with the fox shocks and the high lifter bracket lift. On the rear shocks, upper attachment bolt on the high lifter bracket you will have two small bushings (1 on each side of the shock). You need to add a washer (7/16" hole x ~1 1/4") between each bushing and the black bushing on the shock (2 per shock). I found that my shock had pushed the black bushing over the high lifter bushing and had the shock in a bind. @CumminsPusher @Eltobgi
Thank you!Found a problem with the fox shocks and the high lifter bracket lift. On the rear shocks, upper attachment bolt on the high lifter bracket you will have two small bushings (1 on each side of the shock). You need to add a washer (7/16" hole x ~1 1/4") between each bushing and the black bushing on the shock (2 per shock). I found that my shock had pushed the black bushing over the high lifter bushing and had the shock in a bind. @CumminsPusher @Eltobgi
Thanks CP!@Windrock1000 damn you I thought I was done. Ok thanks so much for the info I owe ya one! Thanks for looking out.
@Tigermark
Mine looked good I wouldn't have even checked but no real miles on either but we'll get fixed up today. .50c in washers would've pissed me off for sure in the bush.
Mine walked over about 1/2" to the front of the UTV
My shock has got a little lean. Might be the new a-arms causing the walk. May move the HL bushings around and slide the shock to the back of the HL bracket.Better then back with the adjuster
Gee, I better check mine!
Are you picking on the elderly againYou are not starting of the day right. No SA comments this early in the morning!
Looks great! That looks like a different machine compared to the last time we rode in Chattnooga. Lol
My middle name is sunshine! I don't know what you are talking aboutAre you picking on the elderly againJeez you know he gets his feelings hurt easily.
then he gets really grumpy
