Working for a living...
43,589
The sad saga of the stinkin' Lincoln
I have good spidey sense when it comes to working on cars, typically. This is exhibit A. Owners relative whose father in law passed and left it to him. Had some leaks, and I was coming in to work extra after July 4th (optional for us, but no pay). The owner asked us to finish the Lincoln up during that time. I commented to my shop foreman that I really didn't want to spend my "off day" working on a Lincoln. He offered to do it, and I ripped his arm off. Because, spidey sense goes off on 22 year old Ford products.
First the power steering hoses. Then the secondary air injection valve broke off. My shop foreman, not having a spidey sense that I do, decided to replace some suspect heater hoses, thermostat and thermostat housing. One of the hoses developed a pinhole leak the first test drive. Then the radiator started crumbling, so got a new one. No it's all back together and running hot...2 months later...
Dodged one, I did...
20190902 153723
20190902 153744
Backwoods
Backwoods
37,766
376,246
Douglasville ga
Getting ready to pull wire next week . This is a diesel power tensioner to hold wire back while being pulled , the puller is on the other end it is very large. Each reel of conductor wire weighs 14000 lbs. We will change reels as they empty , each pull is 2 . 3 miles long it will take six reels. It's going to be fun in the triple digits next week. Enjoy your A.C we'll make sure it runs.
20190905 133153
20190905 133144
there are six wire trailers loaded and ready to go. It will take about and hour each time to put the wire together and swap trailers.
43,589
Getting ready to pull wire next week . This is a diesel power tensioner to hold wire back while being pulled , the puller is on the other end it is very large. Each reel of conductor wire weighs 14000 lbs. We will change reels as they empty , each pull is 2 . 3 miles long it will take six reels. It's going to be fun in the triple digits next week. Enjoy your A.C we'll make sure it runs.View attachment 153533 View attachment 153534there are six wire trailers loaded and ready to go. It will take about and hour each time to put the wire together and swap trailers.
Out of curiosity, I see what looks like...for lack of a better term, a tennis racket shaped wire guide/caddy that appears to make the line do a simple 360 loop. These are in between polls and pretty common. Just curious what it is? May not even be power lines.
Reactions: Biteme
196,418
Communications, ATT, Comcast... typically, lower wires on a pole are low volt, midway up are secondaries, the ones at the top are primaries which are the high voltage ones.
63,071
I was curious what you were talking about and this was the first thing that popped up on google
Upload 2019 9 6 12 49 43
Backwoods
Backwoods
37,766
376,246
Douglasville ga
I think what you are asking is the machine has hydraulic brakes it's pumps are controlled by a person sitting in it . It keeps the wire from going down to the ground while it is being pulled through rollers we call blocks. The wire is threaded around the bull wheels and pressure will be set at 2000 lbs initially and adjusted as needed.the wire is very tight around them it won't slip . It will feed of a few feet and then be put in tension mode it will take a minimum of 2000lds of pull to make it turn. The wire weighs almost 2 lbs per foot . You can imagine what it takes to keep it in the Air will being pulled. The machines and wire reels are much larger than the toys the use on side of the road. It will be a 115 kv line when done
Cyberjunk
Cyberjunk
Berserker
1,622
6,078
Crane Hill Alabama
Well living the retired life after ankle gave out . Spent my youth doing excavation work with my dad till I finished electronics school in 79. Went to work as a technician at a cable company for 10 years till I was able to score a job with a fire dept . As with all fire fighters I took on a second job doing computer recycling and reutilization all th round the 90’s and early 2000 till the economy crashed . Retired from fire fighting/ paramedic 2015 with a bad ankle . So I spend my days trying to get all my projects finished !
BigOL3
BigOL3
2,997
8,921
Spent 32+yrs with LSP Troop L, and retired as Shift Lt. 15 yrs ago. After a couple of yrs of retirement, I started working 8-12 weeks per year on Turnarounds, operating a tractor hauling exchangers in the refineries to make my 'play money'. About 4 yrs ago I also started doing a little work with compact track loader/brush cutter when convenient. At this time the TL250/Vail brushcutter business is picked up enough I really don't care to go back on the Turnarounds ...... lol.
We had the old red/white units when I started in '71, with the old light blue/dark blue uniforms like this ......
DgziTY3U0AAkZcV
then the white units ......
12
then dark blue units with dark blue uniforms .....
16156e8056f2f3720ca32c8e68a140b0
Then back to white units ....
Louisiana State Trooper cruiser
Now they have these .......
5d14e3e8ca1f3image
5a347e47287c3image
Just for laughs .....
On the Turnarounds normally I operated one of these small 70HP JD, on this one in Texas City, I ran the 225HP JD with cab. That was great since most days it was cold, windy, and raining!
0aoURM6BY9ZPLrFDywXZ1mU4MhSOnQNEru3ULDNAee3G0QyU3TGGxHgiMBvcq0WzUVK3JGQNw nc htscontent atl3 1
Now, most of my 'play money' comes from this Takeuchi TL250, with either Vail brushcutter, grapple rake, or bucket.
KTSCvegxpTt9UKQvNz c1TrLilewj68wlo wvOKuULEW1x6s6o5QQysYoq VvQyu55EGlgvjN nc htscontent atl3 1
CHhNWniAuIAOjv8vxOGuKYyHYUB HRbfc86V4LQY5YFr8H7A6K7YRB1Ws4Js4dzQX0eN59Y E nc htscontent atl3 1
ABvfWqhyWtM7pK0QpTW2bNT6fcIGueSHkRrQfxAuqq1m3a8pEaMZeaNNRcByUnYSygzpTPpxi nc htscontent atl3 1
43,589
It is usually the lowest line, and @Adam490 , I think that's it. Google...who knew?
Backwoods
Backwoods
37,766
376,246
Douglasville ga
Saw this rattlesnake today at work , he was upset and rattling
20190910 153634
we are pulling wire this week. It's hot as crap down here
20190910 162037
here's a pic of it coming off the reels
20190910 162047
we just changed reels here's how we put it together to continue pulling . Later it will be sleeved and put together with a 60 ton press.
20190910 175802
BWAF
BWAF
I get paid to pass gas
8,869
42,496
Carthage MO
