“Clutch’s Basket” build
BWAF
BWAF
I get paid to pass gas
8,863
42,472
Carthage MO
Yes for sure. Foam insulation glued to the sides and roof with panelling glued over. Already priced all that at about 200$ including glue.
Ang picked this panelling for the walls so far but we’re going to look around. Got to be easy clean up and take abuse but also be lightweight. View attachment 76236
Good looking siding, I ment the gray tank
322,690
Oh gotcha. Some are insulated but most there’s nothing or a tank heater. For this build I will have everything mounted inside except possibly black water to allow usage in freezing temps so the heat doesn’t need to be continuously on or plugging into shore power.
Reactions: pct, sharp and BWAF
BWAF
BWAF
8,863
42,472
Carthage MO
Keeping a close eye on build ,idea's and learn rv side i know nothing about .In case I build my own
322,690
Keeping close eye build ,idea's and learn rv side i know nothing about .In case I build my own
We learned a lot from building our school bus. Didn’t make many mistakes because we were pretty methodical though. This time there’s things we just don’t need but everything has to be mounted in a 2 1/2 x 8ft section so it’s tight. The positive side is it’ll cause it to be even more efficient and everything is right there so all the run lines will be shorter and no crawling around underneath the the bus was. Keeping everything central is better.
322,690
3 more windows in.
4588513E A77A 427B 973C CD7B21474C13
0452D19E 17C8 44E6 9D65 6433DF4C7175
Placement was critical for what’s being planned on the inside and also outside accessories like the awning, lights and stereo equipment. Also wanted two across from each other to allow air flow for sleeping.
Placed emergency exit window on opposite side as the door
7F6878FA A168 4EEB B4E1 341D492FFDBF
Decided since we saved so much on the glass to do a larger picture window to break up the bus look that’ll be placed in between the door and the window to the left of the door.
65953340 AEEB 42DC 8519 C9433B33FBE1
Also still looking for a small tinted bathroom window for the front of the driver side
BWAF
BWAF
8,863
42,472
Carthage MO
3 more windows in.
View attachment 76244 View attachment 76238
Nice !
Reactions: CumminsPusher
322,690
Looks good what's the Yamaha parked on ?
It looks funny I see that. Just on the front of the trailer
Reactions: sharp and BWAF
BWAF
BWAF
8,863
42,472
Carthage MO
Got the refrigerator! That and the awning are the big ticket items. $250 is a good price for a 3way. He just gave us the stainless kitchen sink so another item off the list!
Just because no one else has ,I'd pay $250 for a good 3way . and Bahaahahah
lee
lee
Village Idiot
2,387
13,522
Springfield Ohio
@CP, is there a build for the bus some where?
Or even some info on what it has and floor plan, not wanting to distract you from 'nest build so if the answer is no that's okay (I'll bug you about it later).
Curious to see what you do for interior walls and electrical / plumbing.
I'm considering a 'tank less' bathroom in my enclosed trailer (8.5' wide, 17' long V-nose)
It will sacrifice one ATV space, currently it hauls 4 ATVs.
Shower and a porta potty, shower only works with full hook up.
Maybe a 'point of use' electric hot water heater - but I'm looking at your water heater also.
Original thought was no pump.
Thinking about it, a 12v pump and a stream and it could be usable.
I think the most likly use will be stay in a hotel while hoofing it across the country then stay at a camp ground.
With a pump and some water cans we could camp remote for a day or two.
Lots of good ideas, thanks for posting in detail.
322,690
I finished the bus before came on here. Only have a few pics. We tore out all the inside steel sheeting and replaced with contact glued in insulation between the steel studs. Then placed sheeting over that also contact glued in.
Propane water heaters are very efficient and only require lpg and two D batteries to ignite. A simple exhaust out the roof or side and a small fresh air inlet are all that’s needed. As it senses a pressure drop(from opening the hot water faucet side) it self ignites and you have hot water.
Really simple. Probably goes through 1/5 the propane for normal usage as a tank.
Also we pulled the shower from the bus years ago and went out door shower. That space was too valuable. The outdoor shower box is 25$ and they have a shower curtain rod that is easily removable designed for motor homes. We usually park with driver side up against the tree line so usually don’t even use that just birthday suit.
Reactions: Cuoutdoors and BWAF
322,690
322,690
What are you doing for ac?
No AC. We had a unit for the bus but never bothered to install it. We do have a stand up that vents outside from a hose through the window that the eu2000 will power easily. If needed could use that.
