Crow_Hunter
I can't imagine WD40 being put in there would do anything but collect fine dust and cause it to get gunky. I took photos of mine in a thread that showed before and after of mine. How my after is set is exactly how the manual says et it and it fixed my issues. However, your park lever also has to be adjusted correctly to begin as I need up having to adjust both. Make sure the vertical free play when in neutral straddles or splits he diff rather than floating above or bow neutral. Basically hold the lever to the right of the neutral slot and wiggle it up and down to verify it is centered.
I will at least check the neutral tonight. I don't notice any issues with shifting right now but I will check just in case.
I am fairly certain from what I remember that the center pin adjustment on my mode is bottomed out on the back of the slot where it should have a 6 mm gap.
Just from talking to the tech on the phone yesterday based on his responses to my questions he doesn't know how it works and he was trying to plug and play and probably just skipped over the must have a 6mm gap portion. I figure it is pretty close since the 2WD did come on at least once last night while I was playing with it.
Thanks for the tips!
I should have just done it myself to start instead of being stubborn and trying to make the dealer fix it.
That will teach me.
