I'm not saying they won't honor the warranty. It just seemed to me that everything that went wrong with the Popo I had wasn't covered. And the warranty had a $100.00 deductible
Do you have to purchase the Honda warranty through a dealer?
The only problem with any other warranty beside Honda is most of the companies behind them are jokes. All of Polaris extended warranties are outside companies, and they wont fix a thing. trust me HPP from Honda is no joke. I just replaced a bubbled painted piece on a 2010 Goldwing with over 60,000 miles on it and HPP covered it. Otherwise the customer would've been out over $700 to fix this problem. Plus I dont know if I'd want the jokers who worked on your P1K doing any warranty work to begin with. Just my two cents.
You can not through a shop rebuild two of these motors for 3800 been there! Have a 12k receipt for that. Unless you're talking a simple rebuild but there aren't near enough miles for that and most people will be out of warranty long before this needs rebuilt. It would take something major to need motor work to this while still in warranty Something that will cost far more then rings bearings. What my dealer said was that Honda tends to question a bit and takes awhile sometimes. I had talked to several people in the shop including my very trusted parts manager and the all said they have better luck with Zurich then with Honda. Most of the time they will start working on the machine before they claim is even okayed because they turn so few down. Now maybe my dealer doesn't have the status with Honda that larger tier Honda dealerships have but I did trust in most of what they said.The only problem with any other warranty beside Honda is most of the companies behind them are jokes. All of Polaris extended warranties are outside companies, and they wont fix a thing. trust me HPP from Honda is no joke. I just replaced a bubbled painted piece on a 2010 Goldwing with over 60,000 miles on it and HPP covered it. Otherwise the customer would've been out over $700 to fix this problem. Plus I dont know if I'd want the jokers who worked on your P1K doing any warranty work to begin with. Just my two cents.
Plus there is no way in hell a clutch problem is going to cost $3800, I've got the 12k piece of paper to show that. Granted mine was a lot of replacing and unless you're talking a very simple rebuild which in that case we wouldn't be talking that for years. If you're looking at a rebuild this soon it's major. you could rebuild this entire engine for that twice over. These guys having no f***ing clue about a thing. Without labor the clutch parts are around $1000, flat rate for that job is 2.1 hours (which isn't that bad really) so for my shop its around $1200.
That I am not sure of 100% but I think you do.
I do know that you have until your factory runs out to buy it.
Wow... Wow... Wow...Update:View attachment 19222
Well, I was right on what I remembered.
This is what they gave me as "fixed". Note that it is no where near the marks in the case and there is definitely no 6mm gap at the back. By the way, that was in turf mode.... That isn't supposed to look like that in turf mode, it is supposed to look like that in 2WD locked!
Looks to me like he just kept tightening until he ran out of room and lied and said it was fixed and no one checked him...
That was my ratchet though. (Thought I took that off before I took the picture, oops.) I was trying to see if I could fit my ratchet in there to back the damn adjustment off, I couldn't by the way. I had to use an open end wrench and my fingers to try and hold it while I took my wrench off and restarted it because there wasn't enough room for the wrench to move. That residual WD-40 "lube" was really "helpful" for making it easier to keep the nut from turning with my fingers s.
I basically had to unscrew everything to nearly zero and start back over from scratch and I can now put it into the correct setting with just my fingers. I hope that is normal and not something else they f'd up.
I will definitely be calling them and giving them a piece of my mind. I hate to get someone in trouble but damn, if you don't understand something don't f*** up someone's stuff being stupid. Ask for some damn help. Hell, I would have rather been back there helping than sitting up front for 2 hours looking at the same machines and videos waiting for them to tell me to go home and then waste a 2nd trip up there for them to not even do that right...
I am also now concerned that if the knucklehead who did this couldn't follow the simple instructions in the manual, what the hell did he do to my differential when he supposedly changed out the fluid!?!? Did he just drain it and not put any back in or maybe use WD-40?
I guess I need to check that now too.
Are the instructions on how to do that in the glove box manual? I looked but I didn't see it, but maybe I overlooked it in my aggravation. I know how to do it on a truck but I didn't see a way to do it on this diff unless it is in the front of the casing.
Chew their ass out. They need to be informed so others don't get screwed and have to pay for it. That is completely wrong. Geez....... What an IDIOT. I would be worried to death about the fact he tinkered with the adjustments/cables in the rear diff. Man, of all the things you were concerned with it should not be your damn dealer's mechanic.
Oh my god crow! 500 is right. You have a legitimate b****!I am hoping since he lied about it working he lied about doing that too. I couldn't see any "box" that he claimed was on the differential that was wrong from the factory that he had to "adjust".
Maybe he adjusted the torque converter instead....
After I put it back to spec it seems to shift fine. It goes into 4WD instantly and diff-lock with a little bit of movement. It goes in and out of turf mode quickly with a little bit of movement. It is better than it was before.
I just wish I had listened to you guys and just fixed it myself to start with.
Yikes, I thought my dealer was bad! Yes, you should be able to turn the adjusters by hand.Update:View attachment 19222
I don't but I think it is a good idea to bring it in for at least the first service so the record is there. By the sounds of it though you may have had better luck at a Walmart service center. I can't believe they did so poor a job
Sent from iPhone
