P1000m5 2017 1000-5 PIONEER LE by UTVMI
utvmi
utvmi
265
574
utvmi
utvmi
265
574
Have bunch of the Led Lights hung but again waiting on packages to arrive, The battery strap showed up and one of the brackets snap while installing it so I went to parts store and got an u joint cap, Way stronger worked great.
The self tapers are both into the steel bars that run each side of the washer tank holder where I put the PC925, The 925 is solid like a rock.
20170618 180412
20170618 180419
20170619 165548
20170619 165556
View attachment 46866 View attachment 46867 View attachment 46869 View attachment 46870
I like your self tapper bars!!
Reactions: sharp and utvmi
utvmi
utvmi
265
574
Pdm 60 is on the way, will be working on wiring everything up in the coming days, also will be venting at same time everything is torn down.
Trying to find more info on Bellows vs Tubing for the vents finding mixed feeling on the subject feel the bellows would give cleaner look and simpler install.
I read somewhere someone burned up a tranny or something with bellows ?
Reactions: Dp5hunter and sharp
105,443
Yup, don't do it! Due the tubing. Look at Traveler II thread to see why.
The right to keep and bear arms shall not be infringed
utvmi
utvmi
265
574
So my back up lights showed up and my 12-6 trailer wire also came in, Tonight I got most everything torn down so I can run wire, vent tubes etc.:D
Got the back up lights mounted and then ran out of time but will be back at it tomorrow night if I get time.
I shot a few pics of the vent lines for anyone that hasn't seen them yet.
Also finding that half of all the hex bolts tops are striped from the factory, want to scream!!! had to use easy out on two of them, Someone @ the Honda plant needs hit over the head with the impact driver...:mad:
20170621 202806
20170621 202837
20170621 202853
20170621 201650
20170621 202359
20170621 182736
20170621 184239
20170621 184315
20170622 000906
20170622 001002
20170622 001014
20170622 001041
20170622 001130
E
elkguide
3,377
7,963
Vermont
Good stuff.
Reactions: utvmi
utvmi
utvmi
265
574
So I had to start the LE up to check, and I have a I 4WD Light on on the dash checked all the fuses there all good, Got to love it, Machine has 12 miles on it,
utvmi
utvmi
265
574
Waiting for wrap/sleeve and filter ends suppose be here tomorrow will take pics of roof line when finished
utvmi
utvmi
265
574
Also ran my 12-6 trailer cable in wrap from second battery all the way to back, Gives me 3 circuits all in one cable run, Will be using two right away and 3 circuit for later item...;)
20170622 115109
20170622 114510
20170622 115727
20170622 123347
Jshell3
View attachment 47065 View attachment 47066 View attachment 47067 View attachment 47068 View attachment 47069 View attachment 47070 View attachment 47072 View attachment 47073 View attachment 47074 View attachment 47075 View attachment 47076 View attachment 47077 View attachment 47078
Did you completely get the reverse lights hooked up? Are they bright enough for your liking?
Do they appear to be indestructible?
utvmi
utvmi
265
574
They do seem pretty close, you would have to hit them really really hard and it would have to be direct hit to center and still might not be enough to break them.
I got them installed on the box, wiring should be done on Sunday that's when my order with more connectors comes in, I just won't pay that top dollar at the stores when I can order 10x more of something for less then store wants for a little package of 3 connectors.
I will post up pics after its done.
COAKLEY
OHIO
Where did you get your rear hitch hook? Cool!
COAKLEY
OHIO
Where did you get your rear hitch hook from?
Reactions: utvmi
utvmi
utvmi
265
574
Similar threads
