BOX1 - TEST
P500 2017 and up P500 step inside...
Ragincajun92
Ragincajun92
163
230
Kingsland, Georgia
I know there has been a lot of questions asked on this subject. We all know that the 2017 and up P500 are geared higher than the 15-16 P500. We have all seen the 15-16 turning big tires with the low gearing. My question is how many of you 17 and up guys are on bigger tires and turning them fine? Seems most of the P500 guys on here are the 15-16 owners. So i’m Doing a roll call for us 17 and up guys
Reactions: RumpRocket
AlR
AlR
470
1,166
Nanaimo, British Columbia
I have a 2017 P5. I’ve got 26x9 fronts and 26x11 rear ITP MudLites on the stock rims. I keep them at 9 psi. I haven’t lacked power. I like the little extra ground clearance.
PS the one inch spacers give me the promise of more stability and still let the rig squeeze between the truck wheel wells.
Al
Ragincajun92
Ragincajun92
163
230
Kingsland, Georgia
516ED22C 07BD 4E5E 9EAD 6DF2AA5E42FE
41BEB1B8 AF0C 49DB 94F4 C85F617487BA
I’m wanting to run 27-9-12 front with 27-11-12 rear on 12” vision 550 4+3 wheels. This is the set up I want.
rocmar
rocmar
4,741
5,773
4 CORNERS
2015...P500 owners
" ORIGINAL OUTLAWS"
ALM76
ALM76
L-I-V-I-N
70
241
Lancaster, Ohio
'17. 27x9 & 27x11 ITP Blackwater Evolution on stock rims. I'm running 6psi. No loss of power.
HUCK
HUCK
1,047
2,314
ARIZONA
My friend put 30s on his 15 and had no power problems at all and better top end .
Reactions: 100Acre
103,525
Like @Alan I am an invisible human ladder bulging at the seams of this and many other prismatic dimensions of explicit grandeur. Gargantuan in imagination...I'm running 25' on stock rims. I'm not sure if another inch would make much difference in clearance and I do have the UMHW under armor which I am very appreciative of. I do think that I may go with a 26" next time though.
Ragincajun92
Ragincajun92
163
230
Kingsland, Georgia
Lol 1” more can make you a hero! The stock tires measure just a little taller then 23”. 27” tires will give you more then 1” making you a super hero and not a zero. Honestly a lot of my buddies I ride with and other people around here are on 29.5 or taller tires. So following them around is hard enough without the ground clearance. Them tall tires dig big ruts and getting high centered all the time sucks.
L
lowtidejoe
24
82
Arizona
2017 P-500 here
Soon to be running the front on 26x9x12 and the rear on 26x11x12 utilizing ITP 5+2 offset black steel wheels
Reactions: 100Acre
U
utahyank
34
37
so you are running these tires on stock rims.....is there any rubbing issues?....can you still pass a gate 52" or less?
ALM76
ALM76
L-I-V-I-N
70
241
Lancaster, Ohio
No rubbing. Tires are an inch wider than stock so you could still squeeze through 52" gate. ITP Specs these at 27.8x8.2, 27.8x10.3 if that helps.
Bushbaby
Bushbaby
67
186
Elliot Lake Ontario, Canada
2017 P5, running big horn 2.0 , 26x9x12 front, 26x11x12 rear on stock rims. No problem, power is ok..
Today i'm in paradise , just receive 4 Elka's shocks stage 2.......
Did you install spacers? I want to use the same tires as you but am not sure of spacer size.
BOX2
box3 - TEST
