P1000 2022 honda pioneer 1000 5 accessories CANT FIND
5,037
22,563
Speaking of the self-tapping screws. I just recently bought a used Pioneer and was crawling around under the thing and noticed that a few of the self-tapping screws were missing and others were loose. Turns out some of the tapped holes were stripped.
Is there a better way of attaching the skid plates? The screws are only attached to the frame which is not all that thick and tubular in places.
What can I do with the stripped-out holes? I hate to go with a bigger diameter screw and make these holes any bigger.
Short version (politely) - get over it, it’s a SxS, not a Bentley. :cool: The ‘perfect’ solution is to drill out each hole for a Rivnut or weld in Tee nut, both of which need bigger holes anyway.
Obtw: I had exactly your mentality when I was (much) younger but came to my senses eventually.
NTCPrezJB
NTCPrezJB
President of #NTC
101,099
902,787
Canton, OH
Nutsert or similar
Nomo
G
GolfCart
125
382
NH
Short version taken politely, and I know it's a sxs and treat it as such (even a looong time ago when I was young). I do however want the skid plates to stay attached. They won't do me any good if I leave them on a trail somewhere. :cool:
I will look into the options listed but looks like I would have to have something welded for the tube frame.
Reactions: Robobrainiac
5,037
22,563
The skid doesn’t care if it’s being held on by 6mm or 8mm self tappers.
Rivnuts and Nutserts install without welding. Rivnuts install like a Pop rivet, you’ll need the pliers; make sure the handles are short enough to fit under the buggy if you don’t have a lift or some such. Both will work in round tubing.
G
GolfCart
125
382
NH
Yeah, I was just looking at them. I'm guessing the self tappers are 6mm, I'll have to check. 8mm could be a solution.
Thanks for the info 👍
5,037
22,563
They‘re 6mm on a Talon but not sure on a P1K.
lee
lee
Village Idiot
2,342
13,147
Springfield Ohio
Skid plate bolts are 6mm (and NOT self tapping).
Everyone loves nut-serts but look at plus-nuts.
I would add gorilla grip glue - wait for the glue to dry before inserting the bolts.
Edit: I switched the link to the YouTube of most interest.
Robobrainiac
Robobrainiac
2,459
8,563
I used rivetnuts on my skid. It is time consuming but people on here really like it.
Post #83
Reactions: CID and WagginTail
