P1000 2023 P1k5 Trail Schematic
PapasTrail
PapasTrail
22
65
Cabot AR
Just got a 2023 Trail Edition and there is a dome light switch and another “do nothing” switch that have wires connected but I’m not finding an unused connector to plug into. Is there an available schematic or can someone tell me where these wires terminate? I assume that are tucked away somewhere under the hood.
Thanks!
JenElio
JenElio
75,056
677,153
Loxahatchee, florida
Thanks!
Welcome from South Florida
First post sooooo, make an intro thread and post some pics of your rig before you get yelled at 😂
I'm not too familiar with the new models but I know there's been mention of them "do nothing" switches and I believe they are just that....."do nothing".....no plug to be found, basically you have to "add" to them. Use the search bar up top and read up on many many many topics 😉 👍
POIDH!!!!
NewHere2
NewHere2
Village Idiot In Training
46,153
352,797
High Plains of SD
Most likely the same as the 2022. This worked for my 2022 Deluxe. Search bar in the upper right is your friend.
Welcome from South Dakota !
PapasTrail
PapasTrail
22
65
Cabot AR
Thanks NewHere2, I had already tried removing the blue tape and found a “capsule” of blue wire crimped together. Kind of why I was looking for a schematic because the wires from the back of those switches have to go somewhere 😬
I guess if it was easy, Honda techs wouldn’t have jobs! I’ll mess with it again this weekend and see if I missed something last weekend.
NewHere2
NewHere2
46,153
352,797
High Plains of SD
Hondasxs explains the wiring further down in that thread. For some reason I can't pull it up when I select the link. find the original post. Better info.
NewHere2
NewHere2
46,153
352,797
High Plains of SD
Newest one I could find.
Best get some pics of your rig posted before the Sheriff calls you out. Rule #4
Reactions: Robobrainiac
NewHere2
NewHere2
46,153
352,797
High Plains of SD
Might find something useful here.
Reactions: JenElio
PapasTrail
PapasTrail
22
65
Cabot AR
The "dead" on/off switch goes nowhere. The blue tape hides the dummy plug with a loop of wire. There are "upfitter" switches only, 3 amp max.
I pulled the blue tape off and there is only a clear “capsule” of blue wires crimped together on the 2023.
There is also an open plug under the front seat but I haven’t checked to see if the wire colors match up to one of these switches.
HondaTech
The blue tape under the hood on the passenger side? There should be one plug with a loop of wire there.
The red plug under the seat is a diagnostic connector.
PapasTrail
PapasTrail
22
65
Cabot AR
Okay, I found the plug with the white wire loop, but the “do nothing” switch doesn’t seem to supply power to it.
The black plug under the seat is powered by the switch with the light symbol on it and there are two more locations in the bed for lights.
PapasTrail
PapasTrail
22
65
Cabot AR
is the do nothing switch supposed to power that connector? Is there a standard plug that will fit that connector?
HondaTech
You could power something with the red plug, but I wouldn't bother. The wire has to be so small to fit the pins it's useless for that.
The dead switch powers nothing, it's there so you can turn on a relay or something similarly low power. It's only rated for 3 amps.
PapasTrail
PapasTrail
22
65
Cabot AR
For sure, the small gauge wires are really only enough for control voltage.
There are so many modifications that can be made, I wish Honda would include an accessory panel for that purpose.
I still haven’t come across a good schematic, is there one out there?
HondaTech
The service manual has a wiring diagram in it. They make a fuse panel but it doesn't just plug into the dead switch either.
