P1000 30" tires without lift
Spoonbill
Spoonbill
213
262
East TN
First off let me say that the ride quality with 30's, foxes and no lift is so nice compared to the 28's, oem shocks and HL lift I previously had. In hindsight I wish I hadn't added the lift. I'm at a similar ride height now compared to the previous setup.
Like what has happened to several here, adding preload to the rear foxes collapsed the lighter "stage" of the coil springs. I replaced the fox rear coils with some 14" 300lb 3" springs. Havent driven with the new coils but seems like it will handle a load better.
Everything clears now, but I cant say what will happen under heavy compression. I have rode with the fox coils and it didnt rub untill I had about 500lbs in the bed (minimal rubbing).
Anyway, the tires are 30x10-14 system 3 xtr370 that measure 29 3/8" tall at 12 psi. The system 3 wheels are 5+2 and I have a 1" spacer on the rear only. Superatv arms on all four corners and fox coils still on the front. Pictures below, buckets for reference (because everyone needs to clear buckets scattered along the trails).
View attachment 199444View attachment 199445View attachment 199446View attachment 199447
SATV arms, fox shocks with bigger springs and no lift. 30” Achilles Desert Hawk MT’s with15” MSA Bead lock wheels.
Incredible set up. Can you advise on the front bumper make and supplier?
View attachment 203199View attachment 203200View attachment 203201
Reactions: Isaiah
Spoonbill
Spoonbill
213
262
East TN
The more I look at your pictures, the more I would like to set My new machine (except the fox and A-Arms). Too many pesos Would you mind sending links for the bus deflectors, bumper, top and windshield?? I just purchased my P12K5 yesterday and need to get it properly rigged out.
Reactions: Isaiah
Hostile1
Alaska
Stock, tires, lift+tires. Without a lift the tires rub on the plastic floorpan where it 90s into the wheel well. You could probably heat it up and push it in if anyone doesn't want a lift but with a full load the rear will rub. I made 1.5" spring spacers for my lift and I wish I would have done 1" front 1.25" rear. Satv arms should be here soon.
20200509 114053
IMG 20200511 191047 639
20200515 202202
107,803
Remington what kind of snorkel setup are your running there?
@joeymt33 snorkel.
Just some pieces put together. He has a breakdown on his travelerII build.
this pic is from 16’ before other mods but its a closer clean look
F4301FC3 BB02 45B8 898D 8A91FE09F39F
Hondoman
Hondoman
727
1,697
Texas
Hondo what offset are you running on your wheels? 5+3? Looks great btw!
5+2, I've since put the highlighter lift back on because it rubs too bad in the rear with a moderate load in the bed. I've also added 2" spacers to the front and 1" to the rear.
Thanks!
PXL 20210115 220708002
Reactions: Russ989 and TripleB
Shelly
178
493
Ty fir the update. Still looks great. I cannot use the highlifter lift. I bought one and then learned thru another post that it will not work with the LE.
Reactions: Hondoman and Isaiah
Russ989
Russ989
22,597
146,820
No
rubbing? Do you just have the forward arms?
I have a lift as well, without it there was some scrubbing for sure. I also have SATV arms from and back.
Reactions: Isaiah
Gold-digger
Gold-digger
108
363
Ocean Shores Washington
Now you have a bucket for oil changes
Reactions: Isaiah and Hondoman
W
wrpowell
5
19
Carbondale, PA
Here’s mine with 30’s and no lift.
View attachment 199534View attachment 199535
Hello from NE PA. Great look! Have a 2020 P1K-5 Deluxe, no lift, upgraded to fox shocks on all 4. Currently running stock tires and rims. Really want to add 30's and rims all the way around. So many different options. Have you had any issues/concerns since doing yours? Do you need to have super ATV arms all the way around? or can you just do fronts? Do you get any rubbing in the rear ? Are all tires same size? Do you have spacers? any offsets? Apologies for so many questions, its crazy all the different options you can go with. Just trying for a simple solution, we do allot of family rides, 4-5 people in machine, 350-450 lbs. in rear.
Reactions: Lady01 and Russ989
