P500 30's?
F
flyboy206
19
22
Will 30's fit. Thinking about trying some tall skinny 30's. 8" front, 10" on the rear, stock wheels.
67,226
Thats new ground.
So far we know..
28's will fit without a lift if you do the frame mod.
There is video of a guy claiming to run 29.5 outlaws.
And... A P5 running a set of Superior Traction tires would be BAD A$$.
So.. Keep us updated.
F
flyboy206
19
22
That would be the ones. Not any side lug, but I like the skinny tire. With the same tire in a 27, only one width.
F
flyboy206
19
22
If someone running 28's could take a pic with the wheels turned, I would like to see how close they are to rubbing.
brianlauritsen
I installed 27" Kendra Bear Claws all around. 9" width front and back. Had to trim the frame rails slightly directly behind the tires. Installed the tires for more clearance and speed. Like them so far, have them aired down to 7 psi but will probably go lower to improve the ride. Love the machine though. Use it mainly in my ag consulting business.
F
flyboy206
19
22
Not mine, but they do fit. I'll be putting a set on Saturday
IMG 4079
F
flyboy206
19
22
Can you give us an update on how these worked out for you? Curious about your impression of ride quality & handling.
I like them so far. Only have about 30 miles on them. I am playing with PSI to find what works best, sidewall says 10 PSI max.
They tend to dig in loose gravel, I would suspect they also would not do well in sand. Everywhere else they work well. This is not a tire for high speed and fast turns.
The Goat
67,226
hello all I have 30x8x12 interforce interco on my P500 they work great I run 4psi and they rub when you go lock to lock on steering wheel sounds like a baseball card in the spokes
Welcome to the club. We would love to see your 500.
Did u do the frame modification? Where is it hitting at?
Thanks.
miano248
miano248
370
398
oceanside long island new york
no I have not didn't feel it was needed for the times I turn the wheel hard all the way left and right the trails I ride on are pretty wide so its not that often it happens but they work great plenty of bite gone thru some mud pits with no issues great ground clearance I had the same tires and wheels on my 2014 rancher dct dealer wasn't giving me any thing for them on a trade in so I took them off and put them on p500 bolt pattern are the same 4/110 front offset same rears are different offset and studs are 12mmx1.5
bobbyhill
bobbyhill
Junior Moderator
1,271
953
Smithfield, VA
Welcome to the Club @miano248 !!
273,508
Nice Looking Ride! @miano248
Reactions: Vaden01
coyhunter
7
I have a set of those on arctic cat rims if anyone is interested they put a lot of stress on your drive train so not going that direction with the p500. I had to replace the cv bearings all around and have another bearing inthe front diff to replace. They are great in the rough rocky trails out west but at a price.
miano248
miano248
370
398
well maybe its just the manufacture artic cat ive had these 30 0n my 2014 rancher with 600 miles on it and no bearing wear what so ever and now I have them on my p500 with 260 miles on rig and no issues that's why people by Hondas cause there built well 8 inch wide tire does not put a lot of stress on bearings
Reactions: sxsinks and JACKAL
