P500 500 won’t shift
U
utahmurf
Grantsville, Utah
2018 500 won’t shift. It is currently in neutral. Last rode it last week then parked in garage. Any one else experience this or have a solution.
67,230
Any noisy like its trying too or anything?
Can you manually shift it with the tool?
Been a few reports of rodents eating the wires and causing similar issues.
Richd
Richd
24
47
Vallejo,CA
i'M SURE YOU ALREADY KNOW THIS BUT...if the idle speed is too high like when you forget to let all the way off the gas, the shifter won't work. Of course that is when you are not moving.
Reactions: Wallace
500oneer
500oneer
15,000 mile club
424
1,080
Central PA
First thing to try is turn the key off and try again.
JollyJoker
JollyJoker
92
192
Minnesota
next thing to try is to check and clean the battery connections and the main ground at the frame. Make sure they are all tight.
U
utahmurf
Grantsville, Utah
If I turn it off then restart it will go into gear, but I have to do that every time I want to go for a ride.
Rustneversleeps
Rustneversleeps
302
582
Talon,New Brunswick,Canada
Any Updates..I'm Just Curious.
Just finish watching a video called my Rancher won't shift ,it may apply to our 500's too..
Might be Starter motor or the gear inside he also checked the angle sensor..
Rustneversleeps
Rustneversleeps
302
582
Any idea where the angle sensor is in the P500?
it's # 9. Hm1016001043
Reactions: trigger
KYhillbilly
KYhillbilly
553
1,663
Ashland, KY
All Honda electric shifts hate a low battery, i had a foreman and rancher and both of those along with my P500 had or have shifting issues if battery is not near full charge. I just put a disconnect switch on the power cable going to my blue sea bus bar that powers my lights and winch. The wireless winch controller is always on and would drain my battery if i didn't run it for a while.
Mudder
Mudder
NTC Ambassador of Walls
11,692
88,498
Same issue here, New battery and voltage regulator required, don’t know if one bad component damaged the other. Looking for a volt meter for the dash so I can monitor it.
