P1000 A Lower Reverse With Talon Parts!!!! - Honda Pioneer 1000
Z
Zmorris83
I down loaded a app on my phone to measure distance and this is what it came up with.
Talon PCM 0 - 30 = 78.3 feet. 0 - 50 = 348.6 feet 0 - 60 = 755 feet.
Pioneer PCM 0-30 81.3 feet 0 - 50 = 387.6 0 - 60 = 826
This was a average of three runs each
The Talon PCM from a dead stop will squall the tires and leave faint black marks turn your tires and mash on it will do a donut on the asphalt the Pioneer PCM would not do it
THANK YOU for sending me your spare PCM. It just got here today and I've already been able to make some significant headway on this project. I was able to confirm a few significant assumptions/suspicions. Side note, I'm almost positive an adapter harness will allow diagnostics and data through the obd connector using a generic OBDII device.
GPR1500SC
GPR1500SC
861
2,426
North East MO
  2. Talon X LV
I can send you a PCM plug if you need it to make a adapter?
Z
Zmorris83
Anyone have a reliable PCM connector diagram and DLC connector diagram?
Louisiana_93
Louisiana_93
10
5
So this is just the talon PCM by its self nothing else?
Reactions: ehart814
GPR1500SC
GPR1500SC
861
2,426
North East MO
  2. Talon X LV
Yes only changes where the PCM while recording those numbers.
But previous mods include
African twin cam
Power Commander and auto tune
Removed the cat
African twin air intake
Reactions: Cummins_sxe
Louisiana_93
Louisiana_93
10
5
African twin cam
Removed the cat
Cat removal requires a tune right?
OK, enough about electronics .. I don't want to mess with any of that. . DO the gears replace the ones in my 2017 to lower reverse? And is it do-able at home?
Ehhhh.. well it depends. What come is your house?
Z
Zmorris83
Still haven't verified that. Looking at a disassembled Sub-trans and the new gears I didn't notice any difference except tooth count.
Reactions: GPR1500SC
Superthrill
667
1,557
North Carolina
Any update on the lower teverse gears?
See a guy on FB attempting it...
russknight
russknight
1,910
7,511
Perry Florida
Isn't that what determines gear ratio?
E
Ericthered
Eric The Red
271
522
Sparks, NV
Can you make a list of parts and seals needed to do the reverse lowering? A kit would be a fantastic help to everyone who owns a Pioneer 1000.
GPR1500SC
GPR1500SC
861
2,426
North East MO
  2. Talon X LV
Just the two gears is all you need
23691-HL6
23701-HL6
Zach said he would do reverse only for $400 shipped back to your door of course you pull the sub transmission and reinstall it.
I am not in anyway part that deal.
E
Ericthered
Eric The Red
271
522
Sparks, NV
Aren't there any seals or o-rings that get changed pulling the sub-transmission? Want to order everything at once to minimize down-time. Thanks, Eric in Reno
GPR1500SC
GPR1500SC
861
2,426
North East MO
  2. Talon X LV
Yes am sure, but I have not done this mod so I don't now what is all needed, Zach said he done it and them to gears are all the hard you have to change, it is on my short list to do what I need is more time.
