Talon Accessory panel and winch wiring questions.
CMB
CMB
5,108
55,092
Ohio
  2. Talon X LV
I have the Talon R
Tramguage1
Tramguage1
Texan
7,601
31,483
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
Hang on
Does yours have the solonoid with the 4 large studs on it?
I may be looking at the wrong diagram
Reactions: CMB
CMB
CMB
5,108
55,092
Ohio
  2. Talon X LV
no it dont.
Tramguage1
Tramguage1
Texan
7,601
31,483
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
Ok so only large black and red connect directly from battery to terminals on winch.
Is this correct?
Reactions: CMB
CMB
CMB
5,108
55,092
Ohio
  2. Talon X LV
yes I cant find the other end of the black where it goes into the harness only red one was in battery box
Tramguage1
Tramguage1
Texan
7,601
31,483
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
CMB
CMB
5,108
55,092
Ohio
  2. Talon X LV
Tramguage1
Tramguage1
Texan
7,601
31,483
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
Do you have a volt meter or 12v test light?
Reactions: CMB
CMB
CMB
5,108
55,092
Ohio
  2. Talon X LV
Tramguage1
Tramguage1
Texan
7,601
31,483
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
Got 12 volts at the 2 terminals on the winch?
Reactions: CMB
CMB
CMB
5,108
55,092
Ohio
  2. Talon X LV
Tramguage1
Tramguage1
Texan
7,601
31,483
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
From the ground terminal on the winch to the small key on power lead 12 volts?
Reactions: CMB
CMB
CMB
5,108
55,092
Ohio
  2. Talon X LV
Tramguage1
Tramguage1
Texan
7,601
31,483
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
@my99svt
Got any input on this?
Reactions: CMB
Ragnar406
Ragnar406
The Great Bald One
4,460
17,085
Bella Vista, AR
Did you hook up the red wire at the battery? The talons come with the wire run but not hooked up? I know you mentioned you were reading 12v but I only saw where you say 12v key on.
thought I would mention since I had not specifically seen
Reactions: CMB
PhilCod
PhilCod
366
762
Indiana
I just did all of this last week. I did not have a black wire by the battery, only the red one. I hooked the red directly to the battery. Under the hood, or cowling you have to remove, you have the red and black wire. I hooked those up to a XTC busbar harness that also utilizes the accessory plug. I wired the winch wires into the busbar and it works fine. My only guess is the black is grounded somewhere or hooked into a wiring harness and that is grounded and linked to the neg on the battery. The R and X are the same when it comes to the wiring.
Reactions: CMB
Ragnar406
Ragnar406
The Great Bald One
4,460
17,085
Bella Vista, AR
So I believe that you should hook the Red (wire from the battery) directly to the winch (or red wire from the winch) and the Black wire (ground honda) to the Black wire ground from the winch. Should not wire to the busbar unless I am not understand what this particular Busbar is
The Black wire (honda) should be tied directly to a honda ground point (already) could check to make sure that is true
Reactions: CMB
PhilCod
PhilCod
366
762
Indiana
What your saying will work, and I think you mean to connect those to the winch solenoid. The bus bar is used if you want to power other accessories. If you buy a kit like the XTC, you can plug the accessory plug, that Honda supplies, into it and then you can run other stuff from that power point. It's a great place to hook relays in for stuff like LED lights. Doing this is just a way to have an easy place to access your power, both battery, and power from the keyed ignition. The XTC kit gives you more power for accessories as it accesses the battery power, and ignition power. Many folks on this site have it as well.
Here is a link.
Reactions: CMB and Ragnar406
CMB
CMB
5,108
55,092
Ohio
  2. Talon X LV
thanks for the help. ive got warn looking into it and is going to call me back shortly. As soon as I find out what the problem is I will post it on here.
