Accessory wiring
Q
Quetico
20
57
If I buy this harness, could I use this to wire into a 6-fuse box, and then wire to accessory switches from there?
Initially I’d only be running a sound bar, but may add other stuff down the road. My concern is the sound bar specs state 10 amps, and this harness states a 10 amp max. Open to suggestions. I struggle trying to understand wiring.
68,264
Hi.
Yes, you could.
But you should not because of the very thing you mention.
It's only has a 10a rating. It's designed more for a trigger wire or at max 1 or 2 small accessories.
Use this to control your stinger or other relay that will send high amp loads to the volt meter.
Barracuda
Barracuda
97
493
Washington state
  1. Talon X4 LV
  2. w/Turbo
I used this keyed pigtail to switch on a relay which then powers up the other relays - essentially doing what you are asking. My accessory relays are also fused and wired to my accessory battery. It can be done without overloading the circuit if you are a little creative...
Mdsiman
Nj
  1. Talon R LV
I plan to get this as well to power a 12v relay, but my question is what to do with my other key on power accesories?
I have my ryco street legal kit currently plugged into the blue plug. And I plan to get the Hess i4wd delete( but I did find out they offer another plug connected to splice).
Should I just cut off the plug of the ryco and go straight to my fuse block?
Reactions: BobFarrell
