P1000m5 Adam490's Short Bus
Haldog77
Haldog77
NTC's Mafia Enforcer (Ret.)
44,332
369,768
Bossier City, Louisiana
Not many people realize that the table where the crawfish are, is specifically for eating mudbugs. Notice the tray with the tators and corn, there is a slot for the heads to slide through. They end up in the trashbags under the table. I guess it's a Louisiana thing because mine is just like it. Thanks for the pics my friend.
Russ989
Russ989
22,645
147,291
Where do these people live, the moon? 😂
Reactions: BWAF and Mudwing
62,510
Cabins are closed.
That's what I thought I had read. If it wasn't a 6 hour drive I'd head up there for a day ride, but hate parking at a hotel with the Pioneer on the trailer. Not being able to ride at night is also a bit of a bummer. Thinking I might head back to Sicily Island this weekend if it dries out some this week.
Reactions: BWAF
They are having several night rides coming up.
wrhii
wrhii
302
1,758
Florida
Reactions: Adam490 and BWAF
62,510
:mad:... Should be riding at RRB right now. Instead she's stuck in the garage with no where to go
IMG 20200423 123054
@Plumber32 @Bad_bowtie and whoever else is up there, drink some margaritas for the rest of us!
62,510
Haven't done much to the Pioneer lately. Bought these gussets from OffroadAnonymous.com a couple weeks ago and finally got around to cutting them to fit the front upper A-Arm/frame tab. Naturally it's been beautiful all week, but when I've got the day off it starts storming 🙄 so I didn't get a chance to tack them in yet. I still need to cut the others to size for the lower arm mount gussets.
IMG 20200508 180316
IMG 20200508 180411
Reactions: joeymt33 and wrhii
Pilotadam
Pilotadam
326
735
Pell City, Alabama
Haven't done much to the Pioneer lately. Bought these gussets from OffroadAnonymous.com a couple weeks ago and finally got around to cutting them to fit the front upper A-Arm/frame tab. Naturally it's been beautiful all week, but when I've got the day off it starts storming so I didn't get a chance to tack them in yet. I still need to cut the others to size for the lower arm mount gussets.
View attachment 201547View attachment 201548
Are those to keep the tab from bending? Or just strength the connection to the frame?
62,510
To strengthen the frame in that section. We've seen a few rip the weld where the front upper arm mount ties into the frame and bumper mount. The lower fronts take some abuse in the rocks so I'm beefing those up as well based off others that I ride with.
@Plumber32 or @ToddACimer might have some pictures of the upper area when they fixed his a while back
ToddACimer
ToddACimer
Pioneer 1005-2
3,811
16,231
Oshkosh, Wi
My upper and lower a-arm mounts are gusseted.
IMG 20200508 205732
IMG 20200508 205737
62,510
Been giving the buggy a once over since she just rolled over 1k miles and has a date with Tackett Creek at the end of the month. I ordered her a BCF harness bar and harnesses as a gift!
1589477920183
1589477941102
Something hit my drivers rear spring retainer and then a rock got wedged under there last ride, so it couldn't reseat. It wore the shock body pretty good:
1589477765236
1589477880389
Got my upper gussets and weld washers (thanks again @Neohio ) welded in and went through the front end. Driver side upper arm bolt was really loose. I can see how people wallow out the bolt holes now. I installed some new locknuts on both sides along with some orange loctite and an extra nut to try and prevent it from loosening up. Regreased everything and put it back together.
1589478154672
1589478637691
Also installed my eBay exhaust tip (Link to listing on eBay). Liking how it sounds and that I won't have to worry about the spark arrestor clogging any more:
1589478377021
This is my stock tip/arrestor:
1589478559650
Next up will be going through skidplate bolts/washers, beefing up crossmembers, and installing my other set of quick release mounts on the rear driver's side seat back. Also need to figure out why my LED whips decided to stop working out of the blue.
Pilotadam
Pilotadam
326
735
Pell City, Alabama
I just removed my skid plate to rebuild my clutches.... but I had all the bolts in the main frame rails round the head off. I think the threads had mud on them that then got stuck in the weld nuts. Have you had a similar problem? All the new ones I welded it to my reinforced outer bars had no issue.
Similar threads
