P1000m5 Adam490's Short Bus
I just removed my skid plate to rebuild my clutches.... but I had all the bolts in the main frame rails round the head off. I think the threads had mud on them that then got stuck in the weld nuts. Have you had a similar problem? All the new ones I welded it to my reinforced outer bars had no issue.
You do not need to pull skids to do the clutches.
62,510
I've only pulled mine off twice and only had an issue with the self tappers in the side rails. I need to order the weld nuts to throw on there.
Pilotadam
Pilotadam
326
735
Pell City, Alabama
Yea I know I didn't. I did it to make the oil change easier and to clean the engine area really good. Note my home made skid plate I did not make the oil drain easy to do with out making a mess.
Reactions: CumminsPusher
62,510
Here's a video I put together from the 3+ hours of footage. Long at over an hour but if anybody was ever thinking about coming to ride this trail it'll give you an idea of the entirety of it.
62,510
Got my BCF harness bar and Aces Racing harnesses in. I'll probably order another one of these harnesses and use them on the rear seats and go with a Dragonfire or pick up the X3 retractable for driver. Everything installed great with the exception of having to drill out the harness lap belt mounts to utilize the factory bolt since no store around me had any 7/16-20 bolts. I could have just bolted them in but it would have been just riding on the threads. The harnesses are really solid and were only $44.95 each with free shipping. I'll probably try the drivers one at Tackett and see how I like it before I splurge on the good stuff.
IMG 20200519 193753
IMG 20200519 193744
IMG 20200519 193559
IMG 20200519 193326
62,510
Do the retractable harnesses. SO much nicer than static harnesses or seatbelts and I can confirm they work when you come to a sudden stop.
Can definitely see where they would be nice. Just finished bolting in drivers side static harness and can't reach a damn thing on the dash anymore once I'm buttoned up like I should be. Gonna give it a go at Tackett and then cruise eBay for a set once I get home. These will go on the rear seats.
@clifforeilly what kind of deal you got on one of those fancy SATV window handle extensions 😜
IMG 20200521 205304
clifforeilly
clifforeilly
WFOSXS.com
795
2,688
Goodhue MN
MEMORIAL SALE , WFOSXS ADJUSTER for SUPERATV FLIP UP SPECIAL OFFER
Order before 5/26, 2020 and receive a free bottle of our proprietary WFOSXS hand sanitizer. Prices start at $90. Satisfaction guaranteed.
www.wfosxs.com
The statements made regarding these products have not been evaluated by the Food and Drug Administration. The efficacy of these products has not been confirmed by FDA-approved research. These products are not intended to diagnose, treat, cure or prevent any disease. All information presented here is not meant as a substitute for or alternative to information from healthcare practitioners. Please consult your healthcare professional about potential interactions or other possible complications before using any product. The Federal Food, Drug, and Cosmetic Act requires this notice.
Reactions: JenElio and Isaiah
62,510
www.wfosxs.com
Thanks for info!
Reactions: Isaiah
Tramguage1
Tramguage1
Texan
7,600
31,472
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
@Adam490
When I ride I leave the shoulder belts latched together but not tightened down. When I need to shift to low or 4wd I just snug them up. When I go back to high I just loosen the shoulders up. Also I added the submarine belt. Helps keep the lap belt in position.
The handle that Cliff sales is HUGE help when in the belts!
P.S. At 6' 4"+ I can reach everything while snuggly belted . 😆
62,510
@Adam490
Yeah, yeah.... I can reach the gear selector but not the drive mode at 5'10".
  • Haha
Reactions: Tramguage1
clifforeilly
clifforeilly
WFOSXS.com
795
2,688
Goodhue MN
The wife and I took the kid yakkin today. Been nice since it flooded, made a bunch of new little sandbars on the river.
View attachment 204055View attachment 204056View attachment 204057View attachment 204058
OMG , I’m so glad I didn’t have a daughter. I could never leave this angel alone. And I’m not creepy. I will never, never understand what it’s like to have a little girl. And I’m glad for that I think 🤔, I worry to much about my 2 boys . God bless you sir!
clifforeilly
clifforeilly
WFOSXS.com
795
2,688
Goodhue MN
Similar threads
