P1000m5 Adam490's Short Bus
Russ989
Russ989
22,645
147,291
They were loctited and double nutted. Still came loose. The terrain we were in didn't do it any favors so I just thread locked again and gorilla tightened it.
🤔 back to the drawing board.
Reactions: BWAF and Ridinfool
Figured out where my slack was when I pulled the wheels to change brake pads. Damned driver upper SATV arm. Anybody ever figure out how the hell to prevent this from loosening or should I just check it every ride??
nope I used red loctite and had to tighten them constantly. Go ahead and order a couple extra bolts.
Ragnar406
Ragnar406
The Great Bald One
4,460
17,085
Bella Vista, AR
I had/ have some issue .. several have been replaced because the threads wear when the nuts get loose .... just need to get the time but I am thinking tac welding the nuts this time
Reactions: BWAF and Adam490
62,510
I thought about doing that but I think it'll just spin it in the nut
Reactions: BWAF
BWAF
BWAF
I get paid to pass gas
8,869
42,496
Carthage MO
Full size nut not jam nut ,drill and tap for set screw maybe
Reactions: Adam490
62,510
... Finally killed a side view mirror on a tree at some point.
Reached out to Chupacabra Offroad to see if they'd sell me one mirror after I killed one running the 50" trails. Found out they have a lifetime warranty! Really easy to deal with and my new driver mirror and mount came in today.
1591645495156
62,510
Been getting some maintenance done on the old girl since I hit my 1200 mile service at Tackett. Changed all the oils, welded in the rest of my tee nuts for the skid plate mounts, and ordered up a PV3 as a Father's Day present :p. Started rerunning wires to the rear for some reverse lights and to try and figure out why my whips died.
Still trying to figure out what I'm going to do about my side rails, but since they are pretty trashed I'm leaning towards cutting them and welding in some real tubing. I know @snuffnwhisky @Delton @ohanacreek (and others I'm sure) added the bracing to the rear but that won't help mine at this point since they are beat to s*** in the middle. @Delton did you ever look into making the side rails any further? I know you had posted about it a while back... Looks like a lot of bends. I was going to cut it right after the first support tube and weld in a new straight piece of thicker wall tubing, then sleeve it on the inside with a couple plug welds. Never done anything like this before but figure I can't screw it up anymore than it already is....right :eek:??
1592272720865
Oh, and added my TCM sticker to the hood :cool:
1592272934686
Pilotadam
Pilotadam
326
735
Pell City, Alabama
I would just cope a new outer tube in. Basically replace the outside rail with a new thicker wall tube.
Reactions: Adam490
211,962
If I would have known how flimsy the side rails are when new and not bent up, I would have slid some 1 1/4 SCH 80 BLK pipe in them and tacked them in, I measured and the 1 1/4 is a good fit.
Mine were bent some I put the angle on it anyway. Behind the B-Pillar was bent up 2-3 inches I cut it bent it down and welded it. The strength will be from the angle and bracing. Ill post some pictures at some point this week kinda busy right now and I haven't taken any yet.
62,510
Same. I would have done that and the angle iron. If these are too far gone I will definitely do it with the new ones.
62,510
That's the problem, mine is bent from the side and upward just after the first bend coming from the A. The rear section that has no support is surprisingly pretty straight still...go figure.
Reactions: BWAF
62,510
You can see the extent of the damage on the driver's side pretty good in this pic:
1592274499189
Passenger is just a slight upward bend that would be easy to fix, but the driver's side is pretty smooshed.
Similar threads
