P1000m5 Adam490's Short Bus
63,037
What GPS program are you using ??
I've just been using the Polaris Ride Command app messing around in the neighborhood. I've got Maprika, Avenza, and oruxmaps that I plan to use when I'm out trail riding. @JACKAL has a lot of great info on Oruxmaps and a step by step install. Just search for Oruxmaps and you should find his posts/threads pretty quick.
63,037
Removed the rear sway bar while I had it up in the air to put the 1"s spacers on. Was an easy job, just unbolted the arm mounts and took the clamps off. Took the lower shock bolt out on passenger side and was able to wiggle the sway bar out with the arm mounts still attached.
IMG 20190724 195117 IMG 20190724 195127
These @RB3offroad spacers are really well made, thanks @Swampmonkey for the deal.
IMG 20190724 193048
63,037
Got tired of fighting the ratchet straps on my Rigid boxes so I added some quick disconnect mounts and used turnbuckles. Came out pretty good! Everything came from Home Depot:
IMG 20190730 181540 IMG 20190730 181538
IMG 20190730 194948
IMG 20190730 190218 IMG 20190730 190309 IMG 20190730 194742
I'll probably get a longer threaded rod with hook for the side of the turnbuckle that has the open hook so I can do away with the link on the top box.
63,037
Seat can still fold up and down with the cleat removed and they sit damn near flush with the ridges in the bed so stuff still slides right over the top.
IMG 20190730 192106
63,037
Saw a cool spot we wanted to check out with our RC crawlers so we loaded up the kids in the short bus and made our way out to this big clay washout.
IMG 20190731 185323
IMG 20190731 185917
Kids got bored about 15 minutes in so I put on a movie on the P1K. They thought it was the coolest thing ever
IMG 20190731 194227
Tested my Rigid boxes out with the turnbuckles and they don't move at all. Really like the setup!
63,037
Here's the boxes with the turnbuckles installed and the seat flipped. I grabbed two 8" clothesline hooks so I could get rid of the top link I was originally using. I'm debating on adding these quick disconnects to the sides of all of my Rigid boxes so I can still get in them without having to undo the hooks for the turnbuckles.
IMG 20190801 190253
IMG 20190801 190403
There’s several ways to anchor them and get into them that people have used and @knuckledeep is making a base mount too.
This is before I did turn buckles for the cooler. The aluminum angle is bolted to the bed using nutcerts. Stayed through Tackett and Takeover this year.
75278F59 9717 4BA2 9F64 4B41FC767F4B
Reactions: Adam490
63,037
I looked at yours and had all the stuff in the cart to do them that way when I found these little quick disconnects for about $4. I like that they are flush with the bed ridges when the clip is removed so I don't have to worry about removing anything, just pop the clips out and toss the whole thing into the box.
Reactions: ohanacreek
Like I said more than one way. My way fits my use and was cheap for me. Cost me more in time than material.
63,037
Not too impressed by the synthetic line. It popped the first time I used it, but I'm going to chalk it up to being cheap ass line. I bought some of the Amsteel Blue stuff to replace it with.
Reactions: CumminsPusher
aauman88
aauman88
1,091
2,846
Dang that sucks. Have link of which line it was so I can avoid it?
63,037
It was bundled with the Hawse fairlead I got off Amazon and had a "protective" cover over the actual rope. I was leery to it since it was so cheap, but I needed the fairlead and a new stopper so I just went with it. They claim it has a 7k break strength but it popped on a straight pull that another Pioneer with a synthetic line pulled me right out of after mine popped.
Amazon Link
Upload 2019 8 19 15 0 17
aauman88
aauman88
1,091
2,846
Astra Depot 50' x 1/4" RED 7000lbs Strong Synthetic Winch Rope Rock and All Heat Guard + Rubber Stopper + Red Heavy Duty Half-Linked Hook for Truck ATV UTV KFI https://www.amazon.com/dp/B079L32WV9/?tag=sxsweb24-20
That’s one I’m using now and it looks identical. I haven’t pulled real hard on it and probably don’t need to
63,037
Haha they look identical, hopefully yours is better than mine!
Similar threads
