P1000m5 Adam490's Short Bus
63,026
Ordered the ModQuad (Open Trail) skidplate this morning. $560 on eBay with free shipping, but if I wanted to opt for the next day shipping it was an extra $948, lol. I'll take plenty of pictures upon install.
63,026
Well it showed up today! Ordered it yesterday morning at 9:30 and it was sitting at my door when I got back from lunch. Can't beat that. Doesn't look bad, will definitely need more holes though.
IMG 20190824 151417
IMG 20190824 145504
Bad_bowtie
Bad_bowtie
Huge member
2,570
15,879
East Tennessee
Went ahead and did my other door mod today before it started to rain. Moved some stuff around and wrote on the door what was in each.
View attachment 150042 View attachment 150043
I need to do this! I added the panels to mine since it was originally a base model. I believe the fasteners are different, guess I should look into what I need to make it work.
63,026
ModQuad skid went on pretty easy. I am missing a few screws and washers so I reached out to the seller, hopefully they make it right. I noticed mine is different than yours @joeymt33
Farm Rig doesn't have any hardware here:
Upload 2019 8 25 13 19 33
Mine had two UHMW spacers that go under the skid here and a longer self tapper that went in that section, which seems to be a poor design on their part:
Upload 2019 8 25 13 22 45
There's nothing to push against the top of the skid where you see the gap with the spacers installed since it's offset. I can definitely see where I'll need to add a few more washers/bolts to pull the front flush with the bottom (using a jack right now). Thinking about pulling the spacers out and seeing what it looks like. I'm curious if anybody else that installed this had issues, since it looks like the design changed since you got yours and others I've seen on the forum.
aauman88
aauman88
1,091
2,846
So you happy with the $560 skid? Thinking about ordering one
63,026
I actually just got off the phone with their "tech". I reached out this morning about the missing screws and washer. They replied in about 20 minutes and had them on the way to me. I asked about the big gap I was seeing where the front meets up with the two big center sections and they actually called me about 15 minutes ago. He said I should remove the spacers that were included. I'm pretty impressed by their customer service, can't speak to the durability of the product yet but it seems solid. Went on easily and everything lined up. I'll definitely need to add a few more screws/washers up front to get it to pull flush with the bottom.
63,026
Got the ModQuad skid on and drilled some extra holes for ventilation/drainage. I definitely need to add a few more after a good ride and wash. I can see where the water/mud wants to pool now so that's next on the list. When I get back from RRB later this month I'm going to fix my side rail too.
@aauman88 the skid seems solid to me. Hit a few stumps and logs on purpose and everything was still together when I checked! If you get one, install with only one of the included 1/2" spacers where the front piece meets up with the two center panels.
IMG 20190831 104930
63,026
My little one is fascinated by the neighbors hay baler, she thinks it is so funny when it spits out the bale. "Dad, it poop a hay!!"
IMG 20190831 161122
Also... sucks being the first one through the trail in the morning when these big bastards are out in force. Harmless, but still scare the s*** out of me when I don't see them until they are dangling off the roof. Pulled 7-8 off just from one thicket.
IMG 20190831 161605
63,026
Needed to grab some cheap straps to help some friends move so stopped by harbor freight... Grabbed a 22" light bar that I was going to try and mount on the front using the Traveller pivoting mounts from tractor supply.
IMG 20190914 182750
Ended up being too much of a bind when trying to tighten it all up so I moved it up to the ROPS
IMG 20190914 201100
63,026
Took a ride around this morning and these doors are going to be awesome for the heat. Gained some heat near our feet after adding the full skid and these seem to let enough air move through to offset that. Hopefully it doesn't increase the dust too bad, but I don't think it will with no windshield.
Upload 2019 9 19 15 21 56
JimmyA
JimmyA
1,644
5,504
Northeast texas
Nice rig! Where did you get the D rings on the front bumper?
Reactions: TripleB
63,026
They are just cheap ones from Home Depot. I wanted them to break if it was really in a bind instead of ripping the bumper off or pulling through. I've winched off of these numerous times now and they show no signs of deformation to the rings/brackets or the bumper.
Home Depot 1 1/2" D-Ring with Bracket
Upload 2019 9 24 13 27 32
The biggest thing is adding some extra material on the backside of the bumper where you are installing these. I've got 1/8" thick steel plate behind that entire area where it mounts.
63,026
Want to thank all the guys that put together the part numbers and how-to's for the trail-side tierod repair (@lee , @JACKAL , and others I'm forgetting I'm sure) . We were able to get him back up and running in about 45 minutes from start to finish with neither of us having ever changed one. Happened right after we got off Dragon's Back.
PgX8VnzJQJSFqUiCP7qTWiJMxQOTrvR4PfmnSk5tYS2LXEwSeAj7wODzR1KhfYPQiW78YzreTZecFtHznjw1024 h768 no
St9PtHaXBbZqjlc09 Pmkwjrfgg3nd54gQM pahBB78WdP9C2XJnCFaLv8NJ mWyl8wVdZ2 pL4 UGMlAKw1250 h937 no
ULOVA nAv9pPX8RR9u1kszsJlXhxNhbp1A5cap SuV9VWF Eeyn69tlS8yEeEK5FGdPNDn Up07xDzKaP5w1024 h768 no
Here's a quick picture that Jackal posted a year or so ago that has all the part numbers for those following along at home:
20180322 223943 jpg
Similar threads
