P1000 Air coming through shifter hole
HivoltageHonda
HivoltageHonda
374
367
Hernando, MS
I finally installed the soft cab last night and the air through the shifter is so bad it's like I don't have a cab on. I remember this being talked about but can't find it. What is everybody doing to stop the air from coming through the shifter hole?
Reactions: CumminsPusher
sporttrac4x4
sporttrac4x4
1,177
2,083
ILL.
20161014 151133
velcros & screws to attach cut seat cover .
sporttrac4x4
sporttrac4x4
1,177
2,083
ILL.
Cant stop laughing! Oh man - i got tears in my eyes.
Not laughing at your mod @sporttrac4x4 but for some reason jtw's reply sent to into a cheech and chong fit. Well, I guess your mod helped a bit... LOL
LOL
HivoltageHonda
HivoltageHonda
374
367
Hernando, MS
Cut out a piece of foam to fit inside the opening. Then cut a slot in the center of the foam for the handle to slide through as you are moving it between gears. Takes away 100% of the wind.
How did you get it to stay behind the shifter on the inside?
sporttrac4x4
sporttrac4x4
1,177
2,083
ILL.
On the back side of the seat cover and right in the center for the mode shifter
Dasmoeturhead
I can't believe y'all are trying to modify Hondas dash heater/defroster stealth vents. Those engineers worked hard to figure that out. Jeez!
Reactions: JTW and sharp
Montana
800
322
Look at the thread
Cover for shifter holes
