P1000 Air coming through shifter hole
175
493
Kansas
That’s an excellent fix!
I thought about this type of fix but boots mounted on the backside. Still looks stock but no air could get through.
Montana
800
322
The blue tape on the bottom contains mounting studs that use the existing holes in the dash
5D7097A1 9591 4EF1 ACFA AC8E601855C3
Reactions: JTW
swsebek
swsebek
2,854
5,835
pa
Can you buy this?
The guy bought it off summit racing.
This sight has a Facebook page called
"Honda SXS riders" and a guy on there made it. They were shifter boots off a vehicle and he retro fitted them. They were cheap too.I thought it was genius idea for you 1000 guys and gals in winter and for looks.His name is Jimmy meservey
Montana
800
322
Kathy If you are asking if the cover
May be purchased the answer is yes I do manufacture them. Thank Larry
406 799 5794
You’ll be happy with Montana’s plate... it looks good and functions as it should! I now notice it blowing thru the gas and brake peddle hole when I wear shorts.
O
OlmanMike
So door bushings in queue not done yet. Tailgate leveled seat belt bypassed. Next modification that should have come factory is the air flow through the shift lever slots. I saw a post from days gone by of shifter boots. A. What size to order B. How to attach. C. If the knobs need to come off how does that happen. This machine is making me weak....
Contact @Montana above
