Air filter
G
Gpop
9
14
Reno
I have a new Pioneer 1000-5 deluxe and an thinking about changing the stock air filter for a K&N but have been told the really don’t fit correctly and as a result are difficult to install. Any feed back?
Reactions: TripleB
5,048
22,627
There are numerous online filter comparisons and K&N repeatedly rates in the bottom third at best. I wouldn't run one of those POS on a street machine let alone something run in the dusty environment of a SxS. I've run oiled foam on dirt bikes for 50 years, the K&N can't hold a candle to oiled foam. Just my experience.
TripleB
TripleB
11,933
101,263
Caryville, Tennessee
There really isn't any benefit of not running OEM filter. Unless you're thinking it will save some coin in the long run. $36 for OEM air filter from ronayers.com. I changed my 1st air filter at 4000 miles. I have 3500 on this 2nd filter. If you follow big groups in dusty conditions, you will probably have to change it more often than I do. But not much.
G
Gpop
9
14
Reno
You don’t feel there is a slight hp gain with K&N and opening the exhaust?
Reactions: toddvdh and TripleB
41,936
Thanks!
Honestly I am a little disappointed in the hp. I stress a little, just would like a bit more. Suggestions?
72HP isn't enough? Are you drag racing or something?
K&N's generally do add a touch of power. The issue is filtration, which is not as good as OEM or maybe a UNI filter. IMO, it's not worth the trade off, esp in a machine with plenty of power to begin with.
Reactions: toddvdh
