air intake noise
big31moe
6
I have 200 miles on my Pioneer and I love it with the exception of the noise created by the air intake behind the passenger. Honda for many years on the generator's muffled the intake to get the quiet operation they have a reputation for. I wish they would have done the same with the Pioneer. Has anybody addressed this on their own and fixed it? thanks
slowdryrider
slowdryrider
574
784
Canada
Because I didn't like were the intake was on the Pioneer plus all the dust that it would draw into the filter I sort of snorkeled mine so that It draws air from right at the top of the Rad. I also installed a pre cleaner filter in that area as well. By doing this its stopped the noise as well as being worried about dust and water possibly getting drawn into the filter and motor. I used some 2" rubber hose and pvc to make my snorkel. I've since come to a conclusion that it would have been simpler to have bought some 2" air seeder hose and use it.The hose is heavy plus by using the hose you would eliminate joins etc: I only have one 90 degree bend.I made and installed this right after getting the Pioneer and haven't had any problems or power loss and I do have 3200 klms on.Remember I didn't do this for water travel I did it because of the poor placement of the air intake .There's just way to much dust created by the tires and backdraft in the factory's design.
Pioneer snorkel 007 Small Pioneer snorkel 001 Small Pioneer snorkel 003 Small Pioneer snorkel 005 Small
Reactions: bobhonda
big31moe
6
Your suggestion is right on!!!!!! I will be doing that asap and thank you for you quick response. Moe
big31moe
6
I got it done I used pvc pipe and glued all joints the sound difference is amazing I put an air cleaner up by the radiator like you did thanks for the idea and have a great thanksgiving Moe
Reactions: bobhonda
bobhonda
9
slowdryrider,
hello, does your air intake modification still on your Pioneer 700 ?
i'm really interested to do that on mine. with "air seeder hose" because i'm worried about factory air intake loud sound !
i made this to mine: P700 - P700-4 dampening intake airbox
thank you for feedback!
Bobhonda,
