Jgroesbeck Member Supporting Member Apr 21, 2020 34 70 18 U.S. Ownership 1000-3 Jun 13, 2020 #1 I noticed a sizable indent in the plastic tubing that connects to the air pre filter. I can't tell if there is a seal or gap when I put the rubber boots back on. Anyone know if this is normal? Thanks.
CID Well-Known Member Lifetime Member Supporting Member Oct 27, 2019 5,759 26,451 113 SE Denver-ish Ownership Talon R Jun 13, 2020 #2 Looks like someone overtightened that clamp and the tube eventually collapsed from the sustained load. Reactions: Cuoutdoors
Jgroesbeck Member Supporting Member Apr 21, 2020 34 70 18 U.S. Ownership 1000-3 Jun 13, 2020 #3 Must have come that way from the factory. It's only a couple months old and this is the first time I've had it off. Reactions: CID
Sjc3081 Well-Known Member Jan 16, 2017 267 444 63 Wappinger NY Ownership 1000-5 Jun 13, 2020 #4 Mine was the same. I slid some three inch white plastic pipe in the sleeve and tightened it down. Reactions: 0860silverado, Haldog77, BigOL3 and 1 other person
TripleB Well-Known Member Lifetime Member Aug 13, 2018 21,136 183,863 113 Caryville, Tennessee Ownership 1000-31000-5 Jun 13, 2020 #5 Sjc3081 said: Mine was the same. I slid some three inch white plastic pipe in the sleeve and tightened it down.View attachment 207676View attachment 207677View attachment 207678 View attachment 207679 View attachment 207680 View attachment 207681 View attachment 207682 Click to expand... Whats the deal with the cannon?
Sjc3081 Well-Known Member Jan 16, 2017 267 444 63 Wappinger NY Ownership 1000-5 Jun 13, 2020 #6 I attached by mistake, it is a civil war cannon in a park in Port Jervis NY
0 0860silverado Well-Known Member Lifetime Member May 25, 2017 964 1,862 93 louisiana Ownership 1000-3 Jun 14, 2020 #7 Sjc3081 said: Mine was the same. I slid some three inch white plastic pipe in the sleeve and tightened it down.View attachment 207676View attachment 207677View attachment 207678 Click to expand... Nice fix!
GlockMeister The Bearded Wonder Lifetime Member Supporting Member May 11, 2016 7,606 35,593 113 Greenville, Mo Ownership 1000-5 Jun 14, 2020 #8 Mine was like that but at the airbox connection...heat from the manifold cause mine...luckily i found it doing a leak test on the snorkel at the time. Reactions: CID and 0860silverado
