What mounts and jack did you use? Think I may go this route bumper/jack.
Mounts
48" Jack
Jack Cover
The mounts come with two sets of "U" bolts (shafts longer on one set for bigger tubes - short set fits 1.75"), my neighbor had some 2" diameter, 1/8" thick steel tubing. A short length of that, sawed in two lengthwise, made two reinforcement pads as I didn't want the U-bolts denting the roll bar tubing. Not saying it would, I just didn't want to find out.
The jack cover (or a cover of some sort) is necessary to keep dirt out of the mechanism.
I added the foam handle cover from stuff I had in stock. Don't know where I got it, but it's nice! Tight enough I had to put it on with compressed air (blowing around edge with air nozzle gets the foam to sort of expand and float on as you push.
