P700 Anyone with a rear bumper?
Smoking Joe
Smoking Joe
134
418
Alaska
Got a 700 pio I want to build a rear bumper for and was wondering if anyone has purchased/built one? If so snap a pic of the brackets! Bed frame is the only place I can see mounting it to if I want to keep the dump feature!
Reactions: Lady01
Buckshot07
Buckshot07
19,660
202,377
I contacted EMP about purchasing just their bumper brackets to use when building my own bumper this week. They said they sell the brackets alone for $60. They will have some in 10 days. They said you have to call them to place an order just for the brackets.
...not sure what I plan on doing yet. ..was going to build the bumper myself with a rectangular tube with recessed reverse/work lights and recessed area for license plate.
DcnWayne
26
Willis, MI
My best friend welded this up for me outa 2x2 & Unistrut. It's kinda low, but better than nothing. To do over, I'd cut a weld the 2x to raise.
IMG 20210907 120354899 HDR IMG 20210907 120306843 HDR
bumperm
bumperm
1,848
6,646
Gardnerville, NV
Be careful on trails with that setup. Any excessive upward force might twist your hitch. Happy trails. 😎
Agree,
Unless you are just driving in flat fields, maintaining departure angle is a consideration. With my "jack bumper", the tailgate opens, but I do have to remove the two hand nuts and jack to tilt the bed - takes a couple of minutes. Departure angle
is still good.
20210819 221858
SP82
SP82
101
356
CA
I have a 1000-5 , I recently bought a kfi rear bumper and like it. Keeps the dump bed wasn’t terrible to install and was less than 150$ sent to my door. Made in USA. Maybe I could’ve done something less expensive if I made it myself but how much less ?? What’s my time worth ? Mistakes etc. From my POV was a great deal and is a nice unit. 6985451a1833fa008af6e3e442f3000b
Sent from my iPhone using Tapatalk Pro
chucksmith0706
280
1,077
Louisiana
Agree,
is still good.
What mounts and jack did you use? Think I may go this route bumper/jack.
bumperm
bumperm
1,848
6,646
Gardnerville, NV
Mounts
48" Jack
Jack Cover
The mounts come with two sets of "U" bolts (shafts longer on one set for bigger tubes - short set fits 1.75"), my neighbor had some 2" diameter, 1/8" thick steel tubing. A short length of that, sawed in two lengthwise, made two reinforcement pads as I didn't want the U-bolts denting the roll bar tubing. Not saying it would, I just didn't want to find out.
The jack cover (or a cover of some sort) is necessary to keep dirt out of the mechanism.
I added the foam handle cover from stuff I had in stock. Don't know where I got it, but it's nice! Tight enough I had to put it on with compressed air (blowing around edge with air nozzle gets the foam to sort of expand and float on as you push.
