Auxbeam RA80xl questions
denniswestfall
44
79
US
I need a little bit of guidance here. When I 1st bought my 1000x4, I used the Honda switch plate with the pig tails. Now I have a couple more accessories and decided to get an auxbeam and swap it all over when I add the 2nd battery.
Questions
1. I've got the factory glass windshield with wiper. Can I use 2 auxbeam spots and do one to turn wiper on, and the other as a momentary to run the squirter? How do I figure out the wire to trigger sprayer?
2. I've got an inferno heater that has high and low settings. Can I set up auxbeam to control on/low/high?
Should I just leave wiper and heater hooked up the way they are and run everything else off aux beam?
115,443
Yes,yes and yes
66,853
Wiper and heater...
Ya they will be fine. Major one is the winch to the second.
Reactions: Remington
denniswestfall
44
79
US
Wiper and heater...
So how do I wire up the high low on the heater with the auxbeam?
I plan on leaving my winch hooked up they way or is now. Not through the auxbeam
66,853
By second, I ment second battery.
I would assume you need 2 buttons. Would have to figure out what wire was for high and which for low.
denniswestfall
44
79
US
I got everything torn apart earlier. I put in a 2nd battery up front. Ran the oem winch positive wire to the isolator, then to 2nd battery. Ran a new pos cable from 2nd battery to winch solenoid. Ran a new ground from 2nd battery to the frame. I left the oem ground on the winch solenoid. That's ok, right?
The list of accessories I want to run off the 2nd battery and auxbeam are
Already oem switch plate wired
Wiper
Wiper washer
Heater high
Heater low
Rear lights
New accessories
Horn
Backup camera
Vhf radio
Which wire do I tie the auxbeam into for switched power?
115,443
You cannot wire it that way. The following will show u how u can use your auxbeam for your heaters power .
You will pick a bank on the Auxbeam and make it your “power source” for your heater and you will use a separate high low switch (that prob came with your heater) for heater speed control.
Also keep in mind, your Auxbeam is a “key on” source only, not “constant power” with key on or off. I use mine as a key on Source for my accessories.
115,443
Wiper
Wiper washer
Heater high
Heater low
Rear lights
New accessories
Horn
Backup camera
Vhf radio
Again the auxbeam is a key on power source, you will have to remove what you have on the OEM switch plate and wire them “separately” on the auxbeam or just leave them as they are wired to the OEM switch plate. As for a horn, I would wire that separately to your second battery with an inline fuse and relay. Thats what i did with my horn.
denniswestfall
44
79
US
I got the wiper all hooked up to the auxbeam. The sprayer wires were easy. It took some time to figure out the wiper wiring for the wiper park position. I found a diagram on here that someone hand drew for the pioneer. I used a relay to make it all work based on the pic. I decided to leave the heater as is with original toggle for now. Thanks again for all the help, everyone. D54874bb0dce14d834dacbf3ddb872ca
