P1000 Auxiliary battery and electrical system installed.
Ericseabaugh
Ericseabaugh
274
2,256
South Central Illinois
Got my auxiliary electrical system done over the weekend! Isolator and most of the rocker switches, and the USB charger outlet from the club store. Switch panel from PBR Products. Mighty Max battery, Cole Hersee solenoid, wire loom, Blue Sea 12 circuit fuse panel from Amazon. Duetsch connector kit from eBay. And everything else from the local parts stores.
20230218 090715
20230219 033433
Buggyman
Buggyman
34,509
294,886
ne. ohio
Got my auxiliary electrical system done over the weekend! Isolator and most of the rocker switches, and the USB charger outlet from the club store. Switch panel from PBR Products. Mighty Max battery, Cole Hersee solenoid, wire loom, Blue Sea 12 circuit fuse panel from Amazon. Duetsch connector kit from eBay. And everything else from the local parts stores. View attachment 376149View attachment 376150
looks good
Ericseabaugh
Ericseabaugh
274
2,256
Good job, those are quality components that should serve you well. The rusty pliers are a nice touch also ..........
Those rusty pliers I found between the winch plate and the front bumper assembly when I took off the bumper to change the wire winch cable to the synthetic one from the club store. The were in there when we bought it I guess. My wife said that the had to continue riding with us so I had them where the auxiliary battery is at. Now I need to find a new riding spot for them!
Ericseabaugh
Ericseabaugh
274
2,256
Very clean and organized, I like that👍
Yeah nothing drives me crazier than a unorganized wiring job with wires just thrown in there all sloppy! Well I guess I some of these idiots out on the highway (big trucks just as bad anymore as 4 wheelers) drive me just as crazy!
Jankyeye
Jankyeye
559
2,497
Tampa, Fl.
That’s a clean install. Curious on the voltage spike from the cole-hersee. Had not heard that problem before.
Ericseabaugh
Ericseabaugh
274
2,256
Thank you very much! Yeah I did a little research and I am going to go ahead and install the diode. Apparently it is pretty common and the diode is less than half the price of 1 rocker switch so I figure what the heck can it hurt! I'd never heard of it either, but then I am definitely no electronics and wiring guru either! Other than gear jamming and working on this damn semi, my other strong suit is welding and fabrication. Worked in a welding/ fabrication shop for several years starting with what should have been my senior year in high school but decided making money and working was more important than finishing school. What a dumb bass I was then, because heck with this economy we'll have plenty of time to work. I think I have to work until noon on the day they toss me in the dirt.
