P1000 backlight or light gear shifters
dale5740
dale5740
886
416
mt airy md
has anyone backlit there gear shifters yet? I have been kicking around some ideas but haven't decided on anything just yet. One idea I had was to put a single led light under the gear shifter area and drill real tiny holes through the letters in the dash D R N ETC... to let light come through when driving at night. Not sure that would work as well as having a SINGLE led up on roll cage behind review mirror in a recessed in TUBE so when u looked at it u couldn't see it, it would be recessed in a small tube so would never reflect off of windshield and your eyes could never catch a glare form it!! it would shine down lighting up gear shift area and I would want it to be dim enough not to light up real bright just enough to see what was going on. Then I thought further on this and thought what about making it a led black light and painting the letters on dash with permanent black light paint (white) and the single led light would light them all up nicely?? what do u guys think and also what have y'all done please chime in and post pictures!! truth is I really have become used to the gears and don't need it lit but a lot of times I have friends and family driving it at night and last thing I want is them grinding gears or anything and after all it would be a nice easy mod!! @CumminsPusher @joeymt33 have you addressed this problem yet on either of your builds?
Reactions: CumminsPusher
39,079
I think the most simple mod is "glow in the dark" paint marker and a dim LED shinning on them.
I'm using just plain "white out" and my interior light turned all the way down does a nice job.
319,555
I've been going to look into it. I figured go pick some stuff from a 4Runner and adjust under a piece of lexan with light. I think pretty simple but it's not top of my list. Easy way is just led strip behind gate but not there yet
Boomboom907
596
620
Washington
Nah it sucks. You can't see your shifter so you still have to search for it. All it does is shine light back in your face. If you were going to do anything it would be to put a very dim led on the front rollbar projecting down to your dash giving just enough light that you can see what your looking for. 152d8d0a6ca64460a61f2c94810481aaF44eefb85c6df04405444707d15b6fcc3529b8702cbbcd5abdc3739a1c353c113f7441fa0169c7a6dade2908dd5e919d394666b1de71c243f185f5196bf337e0
Sent from my Pixel XL using Tapatalk
Jamesgang
Jamesgang
148
297
Kitzmiller, Maryland
I was also thinking of glow in the dark paint. Just don't know how good it would work. At the least it would be a different color in the day time.
319,555
Nah it sucks. You can't see your shifter so you still have to search for it. All it does is shine light back in your face. If you were going to do anything it would be to put a very dim led on the front rollbar projecting down to your dash giving just enough light that you can see what your looking for.152d8d0a6ca64460a61f2c94810481aaF44eefb85c6df04405444707d15b6fcc3529b8702cbbcd5abdc3739a1c353c113f7441fa0169c7a6dade2908dd5e919d394666b1de71c243f185f5196bf337e0
Well that's good to know that backlights won't work. I'd like that actually lit up though if you come up with something please post!
The only real good thing I was thinking was to pull backlit stuff from probably a late 70's-80's Toyota then cut and place right under another piece of plastic.
TractorMan
TractorMan
98
159
I used a small LED light strip that has a 3m adhesive backing. Placed it under the hood on the plastic just below the shifter cut out. The lights are red so they do not effect your night vision and they are not overly bright. Just enough light to be able to locate the shifter easily. I think the strip has 4 or 5 LED's on it. Bought it at Advanced Auto Parts. I still can not see the letters on the dash but that is not an issue for me. Just needed to see the shifter. I wired it to be on when the key is on. Pulls less than 1 amp and LED's last forever. Might outlast me.
Led 1
Led 2
dale5740
dale5740
886
416
mt airy md
I used a small LED light strip that has a 3m adhesive backing. Placed it under the hood on the plastic just below the shifter cut out. The lights are red so they do not effect your night vision and they are not overly bright. Just enough light to be able to locate the shifter easily. I think the strip has 4 or 5 LED's on it. Bought it at Advanced Auto Parts. I still can not see the letters on the dash but that is not an issue for me. Just needed to see the shifter. I wired it to be on when the key is on. Pulls less than 1 amp and LED's last forever. Might outlast me.View attachment 34824 View attachment 34825
not bad!! Im going to get a little single led and put it on the roll bar recessed in a little tube so it wont reflect off the windshield or window fram. I also wont be able to look at it directly and bother me, have it shine down at shifter and paint the letters white pref using black light led and white blacklight paint!! ONLY PROBLEM IS single black light led bulb the right frequency for luminescent features with the special paint I don't know anything about either one!! I know this will work perfect but it will be trial and error getting the right combo without help from someone that knows the right stuff? anyone know what we
need?
