P1000 Beadlock wheel question
GlockMeister
GlockMeister
The Bearded Wonder
7,604
35,569
Greenville, Mo
I recently purchased a set of STI HD beadlock wheels. When they mounted the tires on them they didn't run the bead lock ring all the way against the wheel. I'm running pitbull growlers that have an extra deep rim guard. There's about an 1/8 inch between the ring and wheel . Is this normal/correct? I know there's a few running beadlock @joeymt33 @PioneerPete @sharp .
Reactions: sharp
sharp
sharp
3,757
14,955
Tennessee
Look on the instructions to find torque specs and make sure all of the bolts are at the same torque tightening down in a criss cross pattern. If it's holding air you should be fine.
Image Image
sharp
sharp
3,757
14,955
Tennessee
39,100
Yeah, what sharp said.... get out the torque wrench and go around them. I probably had to do a tightening sequence 10 times per wheel to get them all where I wanted them.
GlockMeister
GlockMeister
The Bearded Wonder
7,604
35,569
Greenville, Mo
Thanks to both of you for the info! I better check them because I saw him run them down with a 1/4 drive impact.
Reactions: sharp
GlockMeister
GlockMeister
The Bearded Wonder
7,604
35,569
Greenville, Mo
Well I broke down all my wheels,cleaned the beads and retorqed the bead ring..Glad I did because they weren't anywhere near what they were supposed to be. I noticed a few imperfections in the bead..These were used tires so that's was expected and I still have a few small leaks. Is any one useing tire sealant such as slime or quadboss. Going to order some regardless but curious if it would help seal the bead imperfections.
lee
lee
Village Idiot
2,342
13,150
Springfield Ohio
Is any one useing tire sealant such as slime ....
Slime has it's place (on the shelf at Tractor Supply).
For what you are trying to do consider a 'tire bead sealant' .
Google it, there are lots of choices.
You want the stuff that has to be ground shipped / is known to cause caner in Kalaifornia.
It's a petroleum based rubber - not really a glue.
It fills in the voids between the tire and the wheel.
Delton
Delton
Honda Fanboy
9,967
31,485
Middle TN
What doesn't cause cancer in California??
207,989
Ya me too! This is the 3rd time I've broke this wheel down. My brain says cut your losses and buy new tires..Credit card says "nooooo!"
Don't you get frequent flyer miles, go for it!
sharp
sharp
3,757
14,955
Tennessee
What size tires do you have?
