P1000 Bilge blower for heat
Swheels
15
14
If I mount the bilge blower in reverse will it supply enough heat for winter use? Anyone with experience with this heater method? Carbon monoxide issues?
Thanks in advance
Reactions: BWAF
mcho
17
NW Iowa
Thanks in advance
I cut a hole in the bulkhead behind my legs and mounted the blower to blow through the hole. My blower did not like running backwards. It will not cook you out but any heat is better than none. I did not have a problem with carbon monoxide. Mark
Swheels
15
14
Thanks for the info. Thought i would mount 2 4" blowers, one facing back to cool and one ducted forward to heat with a vent into the cab.
Reactions: BWAF
319,533
Ran 7" fan to cool and two 3" computer fans in for heat. Works pretty when warmed up
Reactions: BWAF and Remington
Delton
Delton
Honda Fanboy
9,967
31,485
Middle TN
I reversed polarity on my twin 3" blowers with holes/vents in bulkhead. Didn't notice much heat coming out. But my system wasn't very efficient. What JShell suggested is a great idea.
Reactions: BWAF
Barnstormer
57
103
Barnum, MN
I used one 3” blower, positioned right near the exhaust manifold area. I wired the on/ off/on switch to operate the blower both directions and vented out center of seat box just tried it for first time yesterday...10 degrees outside and it made snow on my boots and floor melt. Happy with my results.
Reactions: BWAF and Delton
Delton
Delton
Honda Fanboy
9,967
31,485
Middle TN
It was June when I tried it. That's probably why you noticed a difference and I didn't lol.
Reactions: Barnstormer
OnTheJob
OnTheJob
426
925
Bristol, NY
This is ingenuity at it's best. Question: If the fan isn't always turned on, in either direction, will the heat from engine or exhaust melt or damage the plastic fan? Especially in the warmer months. I'd hate to have to always run the fan.
GlockMeister
GlockMeister
The Bearded Wonder
7,604
35,567
Greenville, Mo
Mine hasnt yet...i have one very close to the header.
ofrcboy
ofrcboy
501
572
Oregon
I hooked a foil vent tube to my blower to a vent below the seat and am happy with the results. Not as good as a heater but provides some heat in winter. I just remove the foil vent tube in summer.
20171112 060453
Barnstormer
57
103
Barnum, MN
I’ll keep an eye on it and report if I notice anything
I’ll let you know if I see anything happening
Reactions: BWAF
Mtnman
17
12
maryville Tennessee
Mine Melted last week end and it was at least 12" from the exhaust
Reactions: BWAF
ofrcboy
ofrcboy
501
572
Oregon
Had mine 1 1/2 winters and 1 summer w/o any problems
Reactions: BWAF
Mtnman
17
12
maryville Tennessee
I was turning it pretty tight and winching at the same time but was afraid to run the fan due to pulling the battery down
Barnstormer
57
103
Barnum, MN
Wow! Mine is 6” from exhaust manifold area and no issues so far.
Reactions: Mtnman
