P1000 burnt clutches poll
Are burnt clutches going to a huge issue with all the pioneers or is it going to be an isolated prob
  • Yes
    Votes: 15 21.7%
  • No
    Votes: 54 78.3%
  • Total voters
    69
dale5740
dale5740
886
417
mt airy md
Are burnt clutches going to be a huge issue with all the pioneers or is it going to be an isolated problem with a few here or there?
If u had to guess.
  • YES = problem
  • NO = isolated issues
dale5740
dale5740
886
417
mt airy md
I vote no.
This DCT has been around for a while. Honda has it figured out.
Most likely a internal part not up to specs.
An internal part not up to specs on all machines or just a couple of units. If all then a recall is in order? If just a couple then more than likely a installation issue on assembly line? I wonder if honda has or already had the fix and started implementing them in new builds and the only people having problems are the ones with early early units anyone tried to cross ref build dates with the people having problems? How many cases are there anyways? I hope this doesn't turn out bad and I have to say I am a true Honda fan and I believe in there quality
DTAGG
DTAGG
166
238
ST GEORGE UTAH/ACCORD LAKES SEVIER COUNTY UTAH
My build date was 9/15 and I got it on October 13th. I have 550 miles on desert trails rocky,sandy,hard pack you name it. I am very impressed with my machine. Checked oil and just as Gold as when I changed it. I have not experienced any shiffting issues as some have mentioned and I got one of the first ones in the state of Utah. I truly believe this is an isolated situation on some bikes. Time will prove my statement right or wrong.
Rippinnrarrin
Waycross
I've had my 1000 for a month with stock tires and it's done in the shop for the clutches slipping going into 1st 3&5 gear and pulsing bad in reverse , really like this machine so I'm hoping the fix the problem
amc019
amc019
480
592
Little Rock, Ar
How many times are you going to ask this same question
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
I think it's isolated issue. And if turns out that it isn't, two words.....class action lmao
PioneerPete
PioneerPete
1,496
3,517
Chattanooga, TN
Thanks for sharing the info. Please keep us posted on your dealer's warranty service.
Hawk53
Hawk53
479
610
Alberta Canada
I haven't pick mine up yet but got the VIN and it is ending in 000272 so was wondering about correlation of failures to build dates but was informed that there doesn't seem to be a pattern.
BobW
mts of wv
I have to look at date and vin# but had my pioneer for 38 days and 248 miles on it. Called dealer today and he said "I'm the first and don't know if its under warrenty WTF
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
Don't know if it's under warranty?? Is he serious??
KevinSC
KevinSC
286
306
Go to a different dealer he is full off shat
Reactions: Montecresto
272,134
What is your machine doing or not doing that makes you ask about warranty service? The above is only your second post here and your first post contained nothing from you only quotes from others. We will be glad to help you but we can't read minds, only twitter limits you to 144 characters so please tell us what is going on with your P1K.
F
faulkner
conroe tx
mine in the shop for two months same thing no idiot light no one dealer want even admit there's a problem good luck
272,134
@faulkner Welcome to the club! Sorry to hear your machine is down due to clutch issues. It has affected some of us including myself, but overall the percentage of machines failing is very low. The vast majority are running like champs. I can say once I got mine back it is 100 percent, I am perfectly happy with it. Hope you get yours fixed soon so you can ride. How many miles on your machine did you have when you first noticed the issue? Most that had an issue experienced it in the first 200 miles of use.
208,726
Mine failed within 16 hours. I bought the service manual for it and it goes into great detail about installing new clutch plates. If your clutch fails Honda replaces the whole clutch assembly including basket, you can't even buy clutch plates from Honda. All or nothing.
208,726
Where do you find build date, would be interesting to see if all the failed units build dates are close together?
208,726
I noticed I had dates written on the bottom of the cup holder inserts.. pretty accurate I belive
I was expecting something more complicated HA like vin # look up
