P1000 burnt clutches poll
Are burnt clutches going to a huge issue with all the pioneers or is it going to be an isolated prob
  • Yes
    Votes: 15 21.7%
  • No
    Votes: 54 78.3%
  • Total voters
    69
Nic
Nic
45
59
Oregon
I've had my 1000 for a month with stock tires and it's done in the shop for the clutches slipping going into 1st 3&5 gear and pulsing bad in reverse , really like this machine so I'm hoping the fix the problem
Whats your build date?
Nic
Nic
45
59
Oregon
Where do you find build date, would be interesting to see if all the failed units build dates are close together?
Mine has a build date plate right on the frame. Passenger side inner front wheel well. At least I am assuming its a build date.
IMG 2938
Reactions: JTW
208,726
I think Honda has got it figured out, had less than 200 miles on mine when it failed. They replaced both clutch assemblies and CHAMFERED THE OIL RELIEF VALVES, I think this is key, when I got mine back, no more CLUNK, just a click while going through the gears. Good luck!
208,726
Got over 4,000 miles on mine and the clutch is smooth working. I keep the rpm over 2,000 so I'm off the clutch.
Do you ride bad trails and do you use it to work around your place? Seems like reverse with a load is the weak link.
208,726
How did yours sound new ? Clunk or click?
Hemba
31
52
Baton Rouge la
Wha
what is the name of the dealer that did this work. City and state???
208,726
Wha
Heart Land Honda, Springdale AR 72762 PH# 479-751-7022
208,726
Check out the video I posted on power issue. My 1000 is doing the same exact thing plus it revs in 1st 3rd and 5th gear????
They chamfered the oil relief valves on minuend replaced both clutch assemblies, no more clunk, just a click while running through the gears.
