![Remington](/data/avatars/m/5/5268.jpg?1618889984)
im having an issue with my Bussmann. I have 2 of the relay connections not working when powerd up throttle relays. 2 problems along with questions. 1-how can I test the relays to see if one is bad? 2- does someone have a diagram that showes witch relay in the panel goes to witch set of wires? I’ve looked all over and can’t see to find this. Here is a pic of a relay I pulled out. I’ll have to do each one individually to Check them if I can’t identify them .
