P1000 Bussmann fuse panel relay issues
109,508
im having an issue with my Bussmann. I have 2 of the relay connections not working when powerd up throttle relays. 2 problems along with questions. 1-how can I test the relays to see if one is bad? 2- does someone have a diagram that showes witch relay in the panel goes to witch set of wires? I’ve looked all over and can’t see to find this. Here is a pic of a relay I pulled out. I’ll have to do each one individually to Check them if I can’t identify them .
3DD18B69 69DB 49BE 81E8 9DC65628F07D
3C70F3FA 918E 46AF 8AA9 DECAEFD2ED5F
Reactions: BWAF and sharp
SickSecBeamer
SickSecBeamer
26
39
Jax,Fl
85 and 86 are your pos and neg when you hook them up you should feel or hear the relay click if nothing id say it’s bad
30 87 and 87a is your source to and from
109,508
Thank you I will try that when I get home much helpful. If knowbody can come up with a diagram as to witch relay on the panel goes to witch color wire, I’ll just have to pull them all to check each, no biggie.
ToddACimer
ToddACimer
Pioneer 1005-2
3,573
14,687
Oshkosh, Wi
109,508
So I put power to 85&86 to all the relays and they all clicked so they are working. After testing them I reinstalled them and my rear lights that were not working are now working. So my conclusion with that was that I had a sticking relay and simply putting power to the coils unstuck the one that was stuck. That said tho I’m still not getting any power out of the tan wire that comes from a relay. I may just have a short in the wire I’m thinking?
70Bones
70Bones
888
3,779
New Brunswick Canada
If you're talking about the P1K, you won't get power on the brown wire unless the key is turned on. It supplies power directly to the fuel pump, and to the fan relay.
109,508
P1. I’m talking about the tan wire on the Bussmann fuse panel thats an aftermarket part
7,196
27,837
If the relay contacts were overloaded or maybe a shot occurred while closed, the contacts could have been damaged. If this is your thought just swap with another relay. If the problem goes away then that's the problem. Also if you suspect a stuck relay I would replace it. We use many of these type replays is my business,. When they cause intermittent problems. The problem always comes back.
109,508
Good point. We change marrs relays also when they stick one time on HVAC jobs. Sounds as if I should treat these the same way
109,508
do you know where the cheapest place to get replacement relays? I’ve found them on amazon but there a bit pricy for a small relay. Could just be the type?
Reactions: sharp
ToddACimer
ToddACimer
Pioneer 1005-2
3,573
14,687
Oshkosh, Wi
Reactions: RedFred1 and sharp
