Buying a Safe. Help?
103,529
I'm sure there are many more gun owners here than let on which is all fine and dandy, I respect everyones right to privacy and I don't know what you keep in them, but I'm hoping folks here can forward any advice for purchasing a safe. Do any of you guys like what you have, and or have any complaints? Recommendations? It's a big chunk of cash but I need something to protect my assests here on the farm. I've been using those cheap Stack On lockers but I really want to make a good investment for my investments. There are lots of safe companies claiming this or that, but I trust y'alls judgement and advice more. Thanks for any advices given!
Hondoman
Hondoman
727
1,695
Texas
I've found they only hold half of what they advertise, especially if you have bolt actions w/ scopes. I agree with @Koda , buy as large as you can handle or have room for. This is coming from a guy with two full size and one half-safe. I could use another.
Here’s the thing... your insurance should cover fire loss. It doesn’t however cover theft. Not unless you have an individual rider for every gun. So, worry less about fire as they aren’t going to survive a raging inferno anyway. And think more along the lines of out of sight out of mind as well as location for a safe to make it as difficult as possible to break into your safe. Liberty Fatboy was the best bang for the buck when I was looking. If someone comes prepared, they’re going to get in regardless. I just don’t want the average meth head with a prybar getting the goods.
Choogsbro
Choogsbro
CEO of Monkey Business
8,144
52,659
Monticello, Ky
I'm certainly no expert but I have a Winchester from Tractor Supply and it has served me well. As somebody has already said bigger is better. Buy bigger than you think you need.
Farmer
Farmer
2,851
16,389
Southern MO
I agree with @JTW I'd worry more about theft than fire. As a matter of fact, actually built one into a false chimney chase void at our old place. You lifted the entire sidewall up and away to access it. The trim and everything came with so it was all one piece. I bet you could find a place in your farmhouse. You seem pretty creative! LOL!
sharp
sharp
3,757
14,955
Tennessee
Defiantly get a big one, if you think one is too big just give it a couple of years you will grow into it. Lol Also a digital key pad takes a fraction of the time it takes to open than one with a dial. Don't worry about the battery dying, it can open about 5000 times before it dies If it does you can change the battery out on the key pad without opening the safe. Another thing you might want to think about after you have picked out the one you want is looks. If your going to put it out in the living room or something you might want to consider a shiny that looks like a nice piece of furniture. If not and you want to put in a garage you could get one with more of a reserved appearance and save a few bucks. I have a champion trophy and love it, many configurations can be made on the inside. Good luck
265,435
I have been extremely happy with my Liberty Presidential 50 safe, 2.5 hours fire rating at 1850 degrees, weighing in at 1680 lbs isn't going to walk off. Unconditional lifetime warranty . Had mine since 2013. They list around $7600 but got mine outright from a platinum dealer special order for $4600. Went with that size because it hold 50 BMG rifles easily and the fire rating.
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
Every make has a different fire rating for temp and hours. It's a joke and a marketing scheme. Many can be easily broken into with a pry bar. They have thin walls. The older safes are better made and a safe from a box store is a cheap pos. I bought a 20 year old Fort Knox with a 5/8" thick plate door. Just the safe weighs over 2000lbs. It's very difficult to move! They dont even make a safe as heavy as mine anymore.
Browse classifieds for old safes or go to an actual safe dealer. If it doesn't weigh over 1500lbs it's not worth buying. Buy the biggest one you can find.
saw1
37
83
Fallon, Nevada
I have a couple of Browning's and they have served me well. FYI if you use the storage solutions rods down the gun barrels, you can stand the long guns straight up, they take up less room and you can store more, this especially works well for scoped rifles.
103,529
What do you guys think of jewelry safes?
Reactions: sharp
O
oldfortyfive
595
1,316
Illinois
Just so everyone is clear what we are all really discussing are called residential security containers and can not in any way, shape or form be called actual safes. If you do your homework you will find out that the so called fire ratings are pretty much a myth. Your stuff may not actually burn, but will be ruined anyway. The insulation is a type of drywall. It works by outgassing moisture to keep the contents cooler. What do you think happens to your stuff when that moisture is outgassed?
If you are worried about fire then the location is key. I have mine in a basement pantry in a corner of two concrete walls and up off the floor about 8" (in case of water). Heat goes up and concrete is a great fire repellent.
swsebek
swsebek
2,854
5,828
pa
I have the liberty USA48 gun safe. If you go any bigger you better prepare to mount it to concrete and then build around it, cause it's a heavy sumbich.If you find you need bigger buy a second one.I would go with mechanical lock"Period". Theft was my concern and fire. Yes I have insurance but insurance can't replace what my dads dad handed down to me. They're value can never be replaced. I keep a fire lock box on the bottom for titles and paper stuff.
Mount that sucker down to concrete and make it so it slides into a spot where you can't get a grinder to the back or to the sides. Because that is there weakness.On the top of mine I have a Four foot by six foot fire blanket that hangs down over the front. This way in case of a fire you have heat kept down. You don't want everyone to be able to see it. Best if knowone knows it's there. That way if you get broke into it's not likely they will bring a bag of safe cutting tools. Also if you can mount it some where in the place that is least likely to be burned area. A lot of times these safes make it through the fire but they fall through the burnt floor and the firemen soak them to hell. Concrete or steel floor. And in a tight spot you can't get your hands along side or behind.;)
Gator
Gator
The Most Unknown Member
2,474
10,381
Louisiana
Ditto on the size. I can't get more than half the guns that mine is supposed to hold.
I also believe in a dial verses digital. I think it's an old school mind set, combined with every piece of electronics I've ever had eventually dies.
NOTE: State Farm told me that only $1,000(?) of my guns were covered under my home owners, unless I carry a policy on them. Talk to your insurance and make sure.
103,529
Floors in my house are only made of wood I have no ability to put in a concrete slab. Maybe I can run the boats all the way through the floor and bolt them from the basement. It’s not really a basement it’s more like a crawlspace.
Reactions: swsebek and sharp
