P1000 Camoplast tracks
JohnyRingo
26
23
I will be putting some Camoplast tracks on my Honda Pioneer 1000-5 this fall and would like to know the overall length of the Pioneer with the tracks. I have searched all over the internet and no one says for certain what the length is. I read "I think" or "should be". Does anyone know for certain what the overall length is so that when I buy a new trailer this summer, I get the right length. I would prefer a 12' drive-on drive-off trailer so that I can use that trailer for hauling my snowmobiles too. I only have room for about 20' in my shop and a 12' drive-on drive-off ends up being 19'. A 14 footer will be 21' and that is too long.
Reactions: BWAF
JohnyRingo
26
23
Here's some info I got from TracksUSA.com. The Camso 4S1 UTV track system will add 26.5" from center of front axle and 35" from center of rear axle. The Honda website has the wheelbase at 80.2". By doing a little math, the overall length "should be" 141.7" or 11.8'. A 12' trailer should work, especially one with a v-nose that will give it another 8-10" in the nose.
Reactions: BWAF
jac
The dealer had one with tracks I measured and I think it was 11’10 thats if I remember right. It was near 12 feet forsure
Reactions: BWAF
Marksir
Marksir
Montana
I would avoid the Camoplast tracks, I have been around 4 sets of them and the do not last. They are cheaply built and can't take any kind of abuse. The tracks will not stay tight, the all plastic bogeys and drive wear very quickly even with mild use. Parts are not cheap, we had a hub bearing fail at work, causing the frame to fall off hub and leave us stranded 4 miles off the road. By the end of it, it was about the same cost to buy a new unit as to replace the broken parts.
Reactions: BWAF and 100Acre
103,531
Thanks for the heads up!
Reactions: BWAF
103,531
I wonder if there's a better set of tracks out there?
Reactions: BWAF
103,531
Have you looked at these?
Reactions: BWAF
lee
lee
Village Idiot
2,329
13,062
Springfield Ohio
I worked on a project years ago where we tried to put an all season track on a vehicle.
There is a reason the military and construction stuff is so damn heavy.
When the track ingests a fist size rock at speed the bogie has to be supper heavy duty or the track has to have a dynamic tensioner.
Either heavy or pricy.
There are some systems that are supper simple and inexpensive.
Based on that they might be worth the hassle.
Dare I say it, popos 6x6 atv half track is one.
The track runs on the rear wheels.
You can throw the track turning sharp on hard ground, but they are relativly easy to to put back on.
When I see the atv track sustems I like to have a look.
They seam light duty to me (the ones I have seen) probably good for snow.
But if there is one that looks good let us know.
