P500 Charging/Jumping Battery under the hood
  • Thread starter Deleted member 3748
  • Start date
Deleted member 3748
Just a reminder - If you have heavy duty battery connections under the hood, you can connect a charger or jump starter under there. Instead of trying to get to your battery box when it's packed in snow... like mine is now. :)
IMAG01034
sgerksinwi
sgerksinwi
203
264
WISCONSIN
I'll have to check
Was this a option or do they all have it?
Thanks
Deleted member 3748
You'll only have it if you installed a winch or intentionally ran battery cables under the hood. I think most of us use winches though.
Deleted member 3748
When I installed my winch wiring I also put in a wire harness with a plug for my charger. It hangs down just under the battery box. Also carry a mating plug with wires for easy jumping.
Yeah... I wasn't that smart.
sgerksinwi
sgerksinwi
203
264
WISCONSIN
I too have the battery Tender hooked up ...
But like you said if it was covered with snow or couldn't get to the battery from the side the under the hood is a neat option,
Maybe Santa will bring me a winch for Xmas
34,175
Well lets not put a silk hat on a pig. I put a volt gauge in mine yesterday and still dont know what it is telling me, so there is that. Looks cool though.
Oops. :)
Reactions: Duckiller
O
oldfortyfive
596
1,321
Illinois
Use a digital meter. Batteries range from dead (about 11.7vdc) to fully charged around 12.6vdc. That's a pretty narrow range and is why a digital volt meter is easier to use. When running, the charging voltage should be between 13.5vdc and 15vdc. Note that the best time to check a battery is at least 8 hours after it was last charged to allow the charge to stabilize. Otherwise you'll get a false high reading. You'll see some variation in this between batteries and vehicles. I had an old Toyota for years that charged at 13.2vdc. That low charge rate helped the batteries last extra years. As lead acid batteries age their fully charged voltage goes lower. Assuming a normal failure mode when you start seeing a charged voltage around 12.3vdc it's time to shop for a new battery.
Duckiller
Duckiller
126
299
Eagle, ID
Gauge is digital. Spent 30+ minutes looking for that EXACT answer but never found it yesterday. Thank you! Tells me that when I see it around 12v I need to start the machine and turn off the stereo! Love this place.
Reactions: rocmar and JTW
hoggr9
88
Xenia, IL
Yeah I put a socket in my dash to plug in my battery tender...fits the plug
I think optima makes it....I too had my tender pigtail hanging out a my battery box...after an emergency launch after dog chasing deer without remembering to unplug tender...I find that the cord inside the cab is a lot easier to remember.
162,426
Gotta pic of that socket? I think most of us here are running tenders and that sounds easiest to me.
34,175
Hey, hey! This thread is about charging under the hood... the old fashioned way. The way it was always meant to be. We don't need any of this fancy crap! :D
Ok big boy, don't start karate chopping anything. :D:D
rocmar
rocmar
4,741
5,775
4 CORNERS
I do a walk around...I got mine
hard wired to battery....then in
black box....
