P1000 Clutch relearn / reinitialize procedure
2018GMC
2018GMC
174
356
AZ
Found this on youtube.
Anyone try this?
Reactions: Russ989
2018GMC
2018GMC
174
356
AZ
I'm getting the clutch update campaign done on my 2017 1000-5 which has 1200 miles on it this weekend.
Should I do this relearn after the clutch update is performed? Or drive normally, then do this after another 500 miles?
HondaTech
I find that its usually unneccessary to do the procedure after the update unless the machine is creeping in gear afterwards.
The reintialization seems to eliminate the creeping I've occasionally seen.
Reactions: 2018GMC
ehart814
ehart814
1,653
3,631
NWPA
Is a relearn something that should be done every so often, or only after clutch replacement? I'm not having any issues at 2300 miles, but I'm just curious if it's something that should be done every so many miles as maintenance. I do notice once in a while when the engine is cold, that the rpms will be kinda high before the clutch engages to start moving
rickoshea
i just did mine after my latest oil change.was it necessary? 🤷‍♂️ .it's a simple procedure so why not?
If it has been 2000 miles and it feels like they are slipping, yes. If it feels like they are slipping, yes. If you have put a tune in the machine, yes. They should do the relearn after the clutch update/replacement.
Engine oil has to be warm. I would suggest driving it for a bit to heat everything up then parking it and letting it do its thing.
ehart814
ehart814
1,653
3,631
NWPA
I'm running the dynojet tune. I've never done a relearn. The machine feels fine, but maybe i'll try to do a relearn this weekend if I think about it
I am not sure if the DJ tune messes with the DCT or not. I have had to mess with the DCT programming because its a Talon ECU in a Pioneer and well lots of changes. It was suggested to me by a member much smarter than me that if I change the DCT, do a relearn and let it settle in. That I might have to do one after it does and I did.
Reactions: ehart814
ehart814
ehart814
1,653
3,631
NWPA
The DJ tune raises the shift points. It may have firmed up the shifts a bit... Doesn't seem drastic but there are noticeable differences. It is an improvement.
I'm asking about the relearn because I've been working my Pioneer pretty hard and I don't want to hurt my clutches. I built a "trail groomer" to maintain the trails on our property. Basically welded together a bunch of scrap steel that was laying around and put a 24.5" heavy truck tire and rim on top of it. I pull it through the trails in low range and it helps knock the ruts and brush down.
Reactions: ohanacreek
5,429
24,931
It's been suggested to do a relearn at each maintenance but I probably won't do it that often, maybe every 2000 or so. My Talon's DCT is working so well at 1500 miles that I don't want to mess with it, low speed engagement is almost perfect for me (although the relearn probably covers more than just that).
