P1000 Clutch stuck in high gear???
bigcountrywv87
bigcountrywv87
West Virginia
I have a p1000-5 with only 170 miles. While riding today the engine stalled. It showed an “E” in the gear box. I believe the clutch got stuck in a high gear because it is having issues going in and out of gear. Switching gears from R to H and back. Won’t even go to L. When I do get it to go in “H” it has vehicle creep at idle. I’ve tried the DCT relearn, but it didn’t help. From my understanding the warranty is expired with the machine being more than a year old. Has anyone encountered this issue and can offer help/suggestions?
Reactions: TxDoc
906UP
906UP
13,003
121,187
da Yoop
Here's the DCT troubleshooting from the Talon manual, I'm guessing it's the same. Are you getting any codes?
Screenshot 20200625 221458 Screenshot 20200625 221519
Reactions: TxDoc
906UP
906UP
13,003
121,187
da Yoop
Is it really an "E" or could it be a dash "--"?
bigcountrywv87
bigcountrywv87
West Virginia
It was definitely an “E” it went away after I shut the machine off and restarted it a couple times, but still seems to be stuck in 2nd or 3rd gear even after the relearn
O
Outdrsman
6
9
I had issues like this with a new machine ended up being lose ground under drivers seat on motor
Reactions: TripleB
bigcountrywv87
bigcountrywv87
West Virginia
Update: I was able to manually put it back in first gear using the tool and the problem still persist (even after doing the trans relearn again). I called dealerships and they checked my vin. It shows that my machine hasn’t gotten the clutch update and has 3 open recalls. I’m hoping that will solve the issues. The down side to that is I’m going to be waiting a few weeks until they can get me in.
Reactions: 906UP
nitzo
nitzo
521
1,105
East Coast, Florida
I don't really know much about these kind of issues. But, this past weekend I had a shifting issue that sounds a bit similar to your problem. The guys here recommended I check my grounds, I did and found I had one that was loose on my battery. You may want to start with checking them.
Reactions: TripleB
If they do the clutch update, make sure they inspect the outer clutch itself. Its most likely burnt and needs replaced. I do believe Honda might pay for it still if you haven't ever had one.
Reactions: 906UP and TripleB
bigcountrywv87
bigcountrywv87
West Virginia
I will mention that along with doing the break in service. Although, they’re so backed up with work right now, they may not do it. What all does the clutch update entail?
1Ktrailrider
1Ktrailrider
183
282
Pennsylvania
The clutch update should have been done if you got it from a dealer. With as little miles as you have it shouldn't be an issue. But when that "E" flashes in the gear position box it's flashing a check engine code. It's stuck in gear because it's going into limp mode so nothing gets damaged. Count the long and short flashes as it blinks. Long flash=10 and short flash=1. Also, when the "E" comes up does it show AT/MT on the bottom? If you did the clutch relearn and it didn't take then that will show up. The only time a clutch relearn is needed is if you made any mechanical changes to the clutch system. I'm assuming you did the CRL after you started having issues.
Reactions: TripleB
bigcountrywv87
bigcountrywv87
West Virginia
I bought it private party. The previous owner just used it around the farm here and there, is the reason the miles are low. The first dealer I spoke with checked my vin and told me that it needed the update as well as 3 other recall fixes. The “E” is no longer on the screen, it went away after shutting the machine off and restarting a couple times. Yes, I did the relearn after having the issues.
1Ktrailrider
1Ktrailrider
183
282
Pennsylvania
Well. I guess the first thing to do is get the recalls on the clutch done. Their is a deadline on the clutch recall. The other is a heat shield for the exhaust, comfort kit under the seat, and gas pedal.
Hawk53
Hawk53
461
587
Alberta Canada
This unit is a 2016 model?
