P1000 Confirmation on second battery that fits! Honda Pioneer 1000
66,871
Looking to make a list on second batteries that fit in the slot under the hood of a Pioneer 1000.
I know the Mighty Maxx and the Odyssey 925 fit great. Who has used a different brand?
Please list below so I can add to the master list.
Thanks.
Batteries that fit for dual battery setup in a Honda Pioneer 1000!
BigOL3
BigOL3
2,994
8,920
https://www.amazon.com/gp/product/B001GN0COE/?tag=sxsweb24-20
51A7uEEPfvL
Superthrill
667
1,557
North Carolina
Interstate SLA 1156 or Interstate DCM0035 AGM on their side fits. I have the DCM0035 AGM in mine and the mighty max is collecting dust.
35 AH as well.
35 AH as well.
But is it a deep cycle....;)
Agm are deep cycle
Yes, but most are good only to 60% discharge for 300 cycles, not 80% 2000 cycles like typical DC batteries. But they sure do have many advantages like working on there sides, under water and at sub zero temps. :cool:
Reactions: BWAF and Eltobgi
Superthrill
667
1,557
North Carolina
From Interstates we sight on that part number.
  • Long life for deep discharge uses
  • Depth of discharge should be between 50% and 80% and recharged as soon as possible
  • Ideal for applications using major capacity prior to recharging*
JimK4343
12
Sarasota, FL
Thanks.
I put a Optima battery on under the drivers seat .. I had a 1/4 aluminum plate laying around and cut to size. Then bolted the aluminum plate under the drivers seat, then drilled and taped for a group 24 battery tray
C9BFA962 CDD2 43DC B39C 52A907322EC2
. It was an extra tray I had from my boat ... it fit perfectly. Now I have plenty of power for when ever the need arises. I also install a Mighty Max in the “hole” to replace Honda's pathetic excuse of a battery from its location. Surprisingly, the Honda starts real quick now. I am assured the Honda’s electrical system has more than enough amps to properly operate.
NFA_Fun
NFA_Fun
82
96
Pinetop, Arizona
Took a quick look at the batteries listed above and seems to be a huge range in price. With those listed, what is the best to run a winch a few times a year but lights and other accessories often?
Out of town and don’t have service to look into all the details but want to get lights, winch, battery, and isolator order to be there when I get back.
Reactions: Smitty335 and BWAF
YardDog
YardDog
Grumpy ol' fart
617
1,937
Arkansas
I gave the interstate dcm0035agm a try. Works great for me. Not sure how it would hold up to heavy winching. But I had the soundbar cranked up and light whips running for two hours and the voltage on the interstate never got below 12.6 volts. Picked mine up local for $116 with no core exchange.
Superthrill
667
1,557
North Carolina
Have winched out a truck and recently been "logging " with it. Been pulling locust logs up into the road to cut up. We will see how well it co continues to hold up.
E
Ericthered
Eric The Red
271
522
Sparks, NV
I installed two identical lithium batteries in the space of the original. Winch worked great with engine running. Pulled a small car out of ditch. Stayed strong all thru the winching. Started sliding the Pioneer, but finally got the Toyota out. Very happy with fast recharge rate and capacity.
66,871
Info please?
JimK4343
12
Sarasota, FL
I put a Optima battery on under the drivers seat .. I had a 1/4 aluminum plate laying around and cut to size. Then bolted the aluminum plate under the drivers seat, then drilled and taped for a group 24 battery trayView attachment 102744 . It was an extra tray I had from my boat ... it fit perfectly. Now I have plenty of power for when ever the need arises. I also install a Mighty Max in the “hole” to replace Honda's pathetic excuse of a battery from its location. Surprisingly, the Honda starts real quick now. I am assured the Honda’s electrical system has more than enough amps to properly operate.
I installed a BT Radio, turn signals from scratch, winch, led light bar, back up lights, and plan for more lights later. It seems my Honda is more like a boat the more I use it ... (break out another thousand) ... I installed the mud busters and they do keep the mud off you .. rear bumper and the list continues to grow. I plan to add the arched adjustable a-arms soon.
31DAAE3C FE36 44FE AC19 F6EEA30E75BD 42FA772A 2839 46B8 B9F3 50871E40DD74
Reactions: BWAF and JTW
