Das Gnomenhaus…Overland Camper Rig
106,259
Instead of a bucket, i might go with this for the camper
IMG 0564
106,259
The aluminum bed is almost completed and it appears my camper will arrive on Friday afternoon.
IMG 7725
IMG 7726
IMG 7727
IMG 7728
IMG 7723
IMG 5113
IMG 5117
106,259
The camper distributor manufacturer pretty much screwed me over on the camper and the delivery. Basically he’d never finished it and I had to finish a bunch of the things, but I’ll get into that later. I got the solar panels mounted and the air conditioner unit mounted on the roof and then got the camper mounted on the truck today. Still have to build out the inside. Do not buy a camper from Bison Overland Campers, is all I can say at this point- I’m too tired otherwise. It’s been a long day.
IMG 6289
IMG 6296
IMG 6294
IMG 6302
IMG 6303
IMG 6309
IMG 6310
IMG 6305
IMG 6306
IMG 6307
IMG 6308
IMG 6311
106,259
Even though there is a half inch bolt with 3 inch washers, top and bottom in all four corners, going through the camper floor and through a reinforced part of the aluminum truck bed. I decided because it’s only foam and fiberglass to add a turnbuckle to each corner. This gives me a bit of peace of mind, especially riding on rough roads. I used 8” eye bolts and they’re mounted into the 2x4 aluminum bed frame rail for structural support ..The gnome gnose….
IMG 6339
IMG 6342
IMG 6341
IMG 6340
IMG 6338
IMG 6337
IMG 6336
IMG 6335
IMG 6334
IMG 6333
IMG 6331
Vikes79
Vikes79
SKOL!
12,059
115,843
South Dakota
  2. Talon X4 LV
Are you considering installing some boxes under the bed, but forward of the rear tires? Might be able to stuff a small portable inverter generator into one of them for transport.
106,259
Yes but likely at a later time. I need to address the interior buildout first.
