Delton
Honda Fanboy
Ive considered rivet nuts on bottom of stock tube so we may be on same page. Notch it so it's a tight fit and have flat piece welded to bottom of slider and bolt it to frame tube. Mount would be unnoticeable.I'd pull the factory off they unbolt. Then bolt up new ones with the outer tube that holds plastics up. Start over is what I was planning. You can also weld nuts to the inside where skid plates mount for much better mounting.
