P500 Diesel air heater for P500
solrus
solrus
1,629
2,511
Montana
I am ride in KY and WV so not a lot of brutal cold weather but still would like something. Instead of permanently mounting under hood looking at the portable version that is in a case and setting in bed and running hoses around rear soft window. Can get a single outlet or 4 outlet.
12V 5KW Diesel Air Heater 4 Holes All In 1 +LCD Thermostat For Trailer Truck Car | eBay
Good find , if you want ready to go one. I decided to enclose it into plastic , more durable case, but don't have termostat installed yet.
Sent from my Moto Z (2) using Tapatalk
solrus
solrus
1,629
2,511
Montana
This is how , I'm going to run my heater 717890100d0b48ea9dc8cd45d69bdedc
solrus
solrus
1,629
2,511
Montana
Inside just one duct that goes under roof and points down above the window in the drive side. Was too dark to take a pic
13,351
64,958
@JollyJoker Would you mind sharing some links for your setup as well?
heater, remote etc.?
Thanks
Reactions: Biteme
JollyJoker
JollyJoker
91
191
Minnesota
Thanks
I would start with a kit like this:
12V 5KW Diesel Air Heater 10L Tank LCD Switch Remote F/ Trucks Car Boat | eBay
There are so many to choose from on ebay and amazon. Just find yourself a kit that has:
3k to 5k
LCD controller
remote
2 outlets
"T" or "Y"
I would also suggest an upgraded glow plug like this:
252069011300 Glow Plug 12V Fit for Eberspacher Espar Airtronic Heater D2 D4 | eBay
As the Chinese ones are at about a 50% failure rate in the first few uses.
These parts take 3-4 weeks to get here on the boat from China.
If you have any more questions, let me know.
Reactions: Biteme and Mudder
13,351
64,958
3k to 5k
LCD controller
remote
2 outlets
"T" or "Y"
Thanks,
I was not sure whether your remote was included in the kit, or you spec'd something else out.
Reactions: Biteme
13,351
64,958
@solrus
I saw some pictures you posted of hunting. Did the heater maintain a decent level of comfort? I just installed uppers on my 1000 on the weekend. I am hesitant to pull the trigger on this until you give a thumbs up.
Are you running the 3000 or 5000 watt unit?
My desire is to stay warm while snowplowing this winter. No hunting or super long trips. More than likely will fire up the heater while the machine is parked in my garage. Allowing it to warm the cab while the engine idles and gets some heat into it before pushing snow.
Reactions: Biteme and solrus
solrus
solrus
1,629
2,511
Montana
@solrus
Go for 5 k unit, thousands thumbs up !!! :). Best and quick way to warm the butt. U can easily install coolant heater, since p1000 way faster warms up and if I remember correctly u have bypass valve installed so coolant already cones from the engine circuit.
But this diesel heater more cheaper and easier to install then coolant based.
P500 cabin it's a huge black hole that sucks warm air, despite this heater able to maintain warm temp.
Reactions: Biteme
pFive
pFive
670
1,267
Greenwood IN
This seems like a great deal, I wonder how it would like living on the back rack in the rain?
(Never mind, they jacked up the price $400 on Ebay of the unit I linked too)
Anyway, it looks like they draw 9 amps at start up but then down to nearly nothing. Do you think it reall needs a second battery if the P5 is running all the time?
And, would it be worth bothering with if I have no windshield? All I do is crawl in the woods at low speed, I am thinking having this blow down my neck and over my head.
solrus
solrus
1,629
2,511
Montana
1. Since price is up, looks like they read this forum :)
2. I would cover burner air intake better then oem cover, or keep it in the cabin .
3. No need for a second battery (I use it only when stationary, so 2 nd battery is must)
4. If u crawl then you are ok, may be 1/2 windshield is better then no windshield at all. Depends how cold outside , minus 20 is a different story then plus 20 or above 40F.
The air flow is good enough.
pFive
pFive
670
1,267
Greenwood IN
Thanks, It is rare that I would ride much in cold weather, but they have one or two rides (Party's) a year that sound like fun but I don't like to go to the mailbox when it is below 20º (And I would not even go if it were below 10º). I would get a windshield, but in all seriousness that area is how I get out after a fall over.
In 5 years we move south but for under $200 I can see me using this for years to knock the chill off. I would build it in a case like yours or even a small cooler in case it rains.
solrus
solrus
1,629
2,511
Montana
Air burner intake, u can move on a side and have a pipe turn down , I would not stress about rain too much. Just move air intake and make it similar way as heater in take
Reactions: Biteme
JollyJoker
JollyJoker
91
191
Minnesota
The battery is on my back storage tray. I used a U1 battery. I put a 15 amp weatherproof fuse on it and used a 16 gauge 3 wire outdoor extension cord to run along the roll bar to the front storage area where I have the heater. I used all 3 wires as the battery cable to a Bosh type relay so that the heater runs on the back battery when the p5 is not running. As soon as you start the engine both batteries are charged. I ran the negative cable from the back battery to the main ground bolt on the frame by the battery box. Unless the key is on the rear battery is isolated. If you have any more questions just ask.
20190218 123217
solrus
solrus
1,629
2,511
Montana
The battery is on my back storage tray. I used a U1 battery. I put a 15 amp weatherproof fuse on it and used a 16 gauge 3 wire outdoor extension cord to run along the roll bar to the front storage area where I have the heater. I used all 3 wires as the battery cable to a Bosh type relay so that the heater runs on the back battery when the p5 is not running. As soon as you start the engine both batteries are charged. I ran the negative cable from the back battery to the main ground bolt on the frame by the battery box. Unless the key is on the rear battery is isolated. If you have any more questions just ask. View attachment 109155
Could you please, show how u mounted your heater? Did u fabricate a plate?
Reactions: Biteme
JollyJoker
JollyJoker
91
191
Minnesota
I used the mounting plate that came with the heater. I drilled a couple of holes in it and used a longer bolt and 2 nuts for the front to go thru the radiator bracket. In the back I made a drop bracket that came off the square support at the rear.
20181025 162019
