P1000 Dip stick issues
Sadielynn
9
6
Tennessee
Did the 100 mile oil service and noticed some oily residue around dip stick the noticed that it wasn’t screwed in all the way and it wouldn’t. Threads are not damaged but will not go that last thread and a half. Oil fill plug srews in all the way in the dip stick hole but dipstick doesn’t. Any ideas?
Reactions: Isaiah
Sadielynn
9
6
Tennessee
There was no o ring on it because I had to clean the threads off.
Reactions: Isaiah
Sadielynn
9
6
Tennessee
Just went and pulled the dipstick to double check for the o ring, didn’t notice before but the oring is still on it but it doesn’t screw down far enough for it to hit.
5,039
22,555
If the threads are cross threaded on the dipstick, you should be able to see it. If you can see 'some' thread damage, I'd pull it into place (crescent wrench) to seat it, the plastic threads are a lot softer than the alum. Pay close attention to keeping it straight as you're turning it in. When doing something like this, pay close attention, if it starts to bind more than the plastic should allow, QUIT. :oops:
Note that the Talon has an obstacle for the dipstick to get past, it's possible for it to be cocked - I think the P1000 has the same obstruction.
wrhii
wrhii
302
1,758
Florida
CID said: Note that the Talon has an obstacle for the dipstick to get past, it's possible for it to be cocked - I think the P1000 has the same obstruction.
Yep . What ever it is, its close to the bottom and when the end of the stick touches, tip can sit on top, or go to either side. but can only be screwed in if the tip is on the correct side of the obstruction. Its a little awkward with the positioning and all. I think I confused myself 🤷‍♂️
