Is the latch tight, does it rattle?I have the bed extender without the spare holder. It’s high quality.
I'm real impressed with my extender. It's very sturdy. It also works as a quasi rear bumper. The quality is excellent. It came wrapped in a shipping blanket with packing around it. Took about 25 min to get it all bolted up by myself. The latching mechanism works perfect. I dod get a tiny rattle at idle from it. I put a small rubber pad on the end of the swing out and it fixed it.
I ordered one Saturday with the spare mounted on the lower bar, that will get the tire 8" lower. I am mostly a high speed desert guy and the consciences from the suspension guys is you need the weight as low and far back as possible to get the Talon suspension to work as best as it can.
Please post some pictures when you get it mounted up.
@Dirt-roadfab question - your site says you can fit a 2 gallon Rotopax on the inside of your extender. It says that's the size that will fit. The Rotopax site has 2 two gallon choices, one with the twist together bottom that measures 17-3/4" x 13-1/4" x 3". The other, without the twist bottom, measures 17-1/4" x 13-1/2" x 3".
My question is - they also have a 3 gallon size that measures 16" x 15" x 4-1/2". Is this close enough in the 16" x 15" dimension to fit you extender? That extra gallon could mean a lot in the desert backcountry with the Talon's smallish 7.3 gallon gas tank. TIA
