P500 Doolin64's C.R.A.P. 500 Build
Deleted member 3748
Can you post a "run-down" of sorts on the Kimpex windshield?
I have my next windshield picked out and I wanted to mention it, but decided I should do my homework on the Kimpex first. I can't even find this windshield for a Pioneer. :confused:
rocmar
rocmar
4,741
5,773
4 CORNERS
I'm gonna go glass...
soon as I save enough....
pennies
8 bennies....
Reactions: ChungasRevenge
ChungasRevenge
ChungasRevenge
148
251
The Land of Nod
Found and example on E-Bay. But, I can't find a good write-up on it.
rocmar
rocmar
4,741
5,773
4 CORNERS
I'm not sure if I have an organ worth donating to scientific research that would be glass worthy..
If I knew the one I had
would..... scratch this bad
wouldn't have..... bought it
I know guys with glass
....one & done....
tired of polishing scratches
out.....every winter.
to each his own
rocmar
rocmar
4,741
5,773
4 CORNERS
Can you get under the "hood". Hate to waste a dealer Freebie.
Tip out....
makes getting in hood
....a hassle.
big black box...
bags on inside of doors
plenty...of storage
....one & done....
to each his own
I'll buy a glass wimdshield when they make one that fully opens
rocmar
rocmar
4,741
5,773
4 CORNERS
This glass tips out on bottom
those that fold....not very ridged
....but everyone's got there own
....deal.
doolin64
doolin64
187
278
EMP was actually my first choice. I loved how simple it mounted. I was worried it wouldn't fit with my Moose roof. So I went with this Kolpin.
I also should add, the windshield for me is a winter option. I plan to run no windshield or back window in the summer. I typically won't ride If the weather is bad anyhow. I never ride with a windshield on my atv either. That was through the winters as well.
As for the Kolpin, supposedly this one is scratched resistant. It mounts easily if there is no roof blocking you. I'd bet it would be a faster install with the Honda roof. It uses six plastic clips to mount. To access your underhood storage you just have pull the windshield up. 4 clips on each side. Leave the two at the top clipped so the windshield rotates up. The vent does not block my view and I'm 6'2. Allegedly this alleviates the negative pressure to avoid dust coming in from behind. I can't attest to that. My vent did come with a broken tab to hold a vent door closed. I called my seller and Kimpex sent me a new one within a week. For now I'll run the original and keep the new one as a backup.
I can't attest to its scratch resistance. It's plastic after so I don't have high hopes. I think glass is the only way to go to avoid that. I'll update as I get more use on it and take it in the trails. 52e35728206c8be2baebb5ccedb7b1f1
I did not use the upper clips as I drilled out the windshield so my roof clamps could mount. This picture is looking up at the roof. The light grey is weather stripping I used to avoid vibration if the roof on the cage originally.
Ba4d72dc5c9c2cc5e8c29de1d6b9b111
Vent
D1fb44c4f65ae877d873912fcfa44f7a
Vent inside with louver doors open
B1e29a02e1bbe5e65812d3658a0ca397
Roof seal
5d84bb7bac0d5fa5b49fe75a0a7cf0a3
rocmar
rocmar
4,741
5,773
4 CORNERS
I can't attest to its scratch resistance. It's plastic after so I don't have high hopes. I think glass is the only way to go to avoid that. I'll update as I get more use on it and take it in the trails. View attachment 29833
Vent
Roof seal
Kool dude...seen them....wat the
$ on that...
all plastic scratches. ..your rideing
In dirt..mud..rocks..woods..ect.
We do like the full windshield
...above doors is plenty of
air ... lots of dust..if cold don't
Ride much... how much air..
you get from that vent?..
kinda of a kool look
doolin64
doolin64
187
278
I paid $228 shipper off of eBay.
There is airflow from the vents. But it's tough to discern how much. I only zipped around my neighborhood. Otherwise moving firewood was too slow to have air movement. I definitely update you guys more as I get time on it.
rocmar
rocmar
4,741
5,773
4 CORNERS
Definitely a great price...
Reactions: JTW
