P1000 Dual battery charging
budmccarroll
budmccarroll
5
7
Destin, Fl
Searched and I couldn't find anything.
I have the stock battery and a Lith second battery. It is run through the isolator. What do I use for a tender charger? I can I use a standard on the regular? Will it charge the Lith or hurt it?
Thanks for any help.
Reactions: Tundra20
Tundra20
Tundra20
316
813
Arkansas
For a charger u can use pretty much any trickle charger ur batteries should be wired series together so it will charge both batteries at same time ur charger should say what type batteries its good for chargeing battery tender should be ok idk as i use a charger from MOOSE it wrks great
Hope this helps
Tundra20
Tundra20
316
813
Arkansas
Heer ya go
7D3F2EDA F9C6 4B4F 926E E6F129D3AF1C
